y-pipe; bees in a can problem fixed without exhaust wrap
Old Mar 21, 2004 | 04:34 PM
madmax98's Avatar
After installing my y-pipe, I heard the noise described by many people as the "bees in a can" problem. Since I did not want to void the warranty by warpspeed on the pipe, I decided no to use the exhaust tape to fix the problem. The rattling noise was loudder when the car was cold and when I stepped on the gas pedal. Since the inlet piece on the y-pipe that bolts on to the cat converter is not attached to the tubbing of the y-pipe, it was causing the y-pipe to rattle against it. Once the car warmed up, the heat caused the y-pipe to expand, reducing the noise, but not eliminating it completely. I took the car to a muffler shop where I had them weld the inlet of the y-pipe to the tubbing on the y-pipe (on the y-pipe side before the cat converter). Let me just say, WOW! No more noise, and I could finally step on the gas without feeling like a ricer. Only cost me about $15, but it made a huge difference.
Old Mar 21, 2004 | 04:50 PM
mzmtg's Avatar
Minister of Silly Walks
What?
I have no idea what you're talking about.
Old Mar 21, 2004 | 04:55 PM
liqidvenom's Avatar
brotherhood of tq
i have the bee's in can noise and it doesnt bother me cause i can beat most ricers out there. But if u could better explain what u did i wouldn't mind getting ride of it for 15 bucks
Old Mar 21, 2004 | 05:00 PM
skiboarder72's Avatar
Originally Posted by mzmtg
What?
You lost me too
Old Mar 21, 2004 | 05:03 PM
madmax98's Avatar
if you look at y-pipe (the end that bolts on the the cat converter), it has the connector that bolts on to the cat. That connector is free-flowing on the y-pipe until it is bolded on. After you have installed the y-pipe on the car, and bolted the connector to the cat converter, have that connector welded on the tubing of the y-pipe to prevent rattling.
Old Mar 21, 2004 | 06:34 PM
mzmtg's Avatar
My pipe does not have a free floating flange.
Old Mar 21, 2004 | 10:20 PM
1996blackmax's Avatar
I think this is only on the Warpspeed y-pipes. I know exactly what he is talking about. The part, a flange that bolts to the cat is not welded on to the y-pipe itself, you can actually move it around. When you tighten the cat bolts on to this it brings the y-pipe and cat together. I think WSP is the only company that does this.
Old Mar 21, 2004 | 10:47 PM
optimus310's Avatar
wait.....
WHAT?????????
Any one has any pics of it to see what he is talking about?
Old Mar 22, 2004 | 05:04 AM
madmax98's Avatar
[IMG]http://www.warpspeedperformance.com/nissan.htm[IMG]
the connector past the flex section on the warpspeed y-pipe is free-flowing. After you get it bolted on to the cat converter, have it welded on to the tubbing of the y-pipe
Old Mar 22, 2004 | 05:37 AM
optimus310's Avatar
ok I see it now. Well I think thats the only pipe they make like that. But the bees in the can is different. I guess people with WS should worry about this issue.
good info man!
Old Mar 22, 2004 | 06:13 AM
maxspeed96CT's Avatar
The original VQ...
ya man you had another problem, the been in a can noise has to do withthe flex section. My noise is minimal now after making a few gehto hangers and stuff.
Old Mar 22, 2004 | 06:46 AM
happyricefob's Avatar
V^___^V
get a new exhaust gasket
Old Mar 22, 2004 | 09:19 AM
Maxtank's Avatar
Yeah, i'm wondering if he put the gasket on, or if he didn't tighten it enough.....
Old Mar 22, 2004 | 09:23 AM
madmax98's Avatar
it has the gasket, but that is not where the problem is. The problem is on the actual tubbing of the y-pipe rattling against the ring on the connector, and that is where the weld is placed to fix the problem
Old Mar 22, 2004 | 10:01 AM
V^___^V
u mean the extra prong that used to held the stock y-pipe? you can remove that. u won't need it for aftermarket y-pipe.
Old Mar 22, 2004 | 10:56 AM
Spaniard's Avatar
reading this thread gave me an idea...
Do you think i might see a reduction in the bees in the can noise if I bought a simple gasket (metal) and tightened it around my y-pipe flex section?
Old Mar 22, 2004 | 05:35 PM
madmax98's Avatar
no, not the extra prong. you simply weld the connector (the one that is already on the y-pipe) to the actual y-pipe. for some reason, warpspeed makes their y-pipe with a free-flowing connector, causing it to rattle when you hit the gas pedal.
Old Mar 24, 2004 | 03:12 AM
Nismo98's Avatar
WTF, can someone please point out the problem. I really don't hear any beens in the can sound on my 98', or maybe it's just me.
Andrei
lowpost99
Oct 26, 2025 06:53 PM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
