Easy way to take off rear rotors?!
the fronts have holes which u can place screws in but the back doesnt. HOW on earth do i take these off. I tried banging but it doesnt seem to be enough. Thank god i started this in the morn so i have time for an answer. PLease help anyone that has changed rear rotors
Originally Posted by AusFlt
just tap it with a hammer...if they are junk hit it hard. Than just keep turning it around and hitting it.....it takes time but it will come off
and someone told me u dont push the rear caliper pistons back in like in the front, you have to turn them? what is this about?
Originally Posted by meccanoble
f#ck man, its not working at all!
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
Get one of these and bang the backside of the rotor hard. Also turn the rotor after each hit. It will come of eventually.
Regarding your other issue. To get the rear caliper piston in you have to apply pressure and turn it. You need to do this is if you are going to put in new pads, since the new pads will be thicker. There are slots in it to grip it. You can use a tool like this or a pair of pliers.
http://www.discbrakesrus.com/pistontoolrear.jpg
Notice this tool has different sides to fit different piston grooves. You can probably find this tool in the Sears automotive center.
One word of advise. Get the Haynes manual for this car. It comes in handy.
http://www.amazon.com/exec/obidos/tg...glance&s=books
you can get the little tool that cobra man listed above at your local auto parts or napa. It attaches to your ratchet and you put on the piston and turn it. If your rotors and calipers are old and rusty like mine you will not be able to do it with just pliars. I would get the tool.
Originally Posted by Mishmosh
Are yours aftermarket rotors because OEM has two holes just like the front ones do...only smaller holes (M8 size).
I cant run to sears right now, my car is on 3 legs, i need a resolution involving what i have as tools, and a little science. I'm so tired man, i'm bout to give up
are back brakes used anytime besides wit ebrake cause if i put this stuff back, the pads are gonna be messed up....
God i'm so f*cking mad right now. Its already hard for me as a noob, why these dumb a$$ obstacles have to come up. I just went to nearby gas station a block away to ask if i drove real slow with calipers hanging would they bang rotor off for a good price, they talking 40 dollars each side. F#CK THEM!
plan b. i just went to my boy's house and got some WD-40, sprayed the sh*T out of the hub then going back to work. I didnt get any sleep man, thats probably why i'm mad, i wanted to be done an hour ago and have enough sleep before work but like all DIY's done by Mecca, things just take much longer than expected :rollseyes:
Originally Posted by A5295
Proud to hear ya got it off. Now lets hope everything goes back to gether easy. I know your pain about things taking longer. Its the same way with me.
I have work at 5 so i guess i'll only be able to do one side. I should be ok right? unbelievable how it took me 7 hours to do one side......
Heres a tip. Buy some antiseize, and apply it thinly over the part where the rotor touches the hub. That way it won't be a b|itch next time you replace your rotors. They should come right off.
doctorpullit
Sep 10, 2015 06:33 PM
