Programming Keyless Enty Remote
I recently purchased a 1996 Nissan Maxima GLE but it didn't come with the Remote Keyless Entry. I purchased one off of Ebay with the matching numbers and I was told it was very easy to program. Does anybody have a set of directions to perform the programming? Thanks in advance.
1. sit inside the driver's seat.
2. close and lock all doors.
3. In TEN seconds, insert and remove the key 6 times. DON'T RUSH. You will see your hazards blink twice.
4. turn the key to ACC position and press a button on your remote. If you see your hazards blink twice again, you're all set. If not, new batteries or something else.
Originally Posted by jawwaad05
wat if i never see the hazards flash after i put it in 6 times in 10 seconds ??
i do have it ive been using it for aabout a year now i just dropped my remote and it stopped working so i changed the battery i dont understand why wont the lights flash cuz that doesnt have to with my remote thts just clearing up the old code
Do as follows
1) With battry removed , press lock key on remote, this will clear id from unit
2) now install battry
3) Follow as described by DaBombX
4) If it still does not work than probably you have reached maximum limit of 4 remotes in ECM, You can take the car to dealer and get ECM reset
5) Or you possibly have bad remote.
afterwards you want to try and unlock the doors with your remote. i did this in my GXE and it worked perfectly, down to the automatic windows. (if you press, release and then hold down the unlock button, for about 3-4 seconds, your windows on your drivers and passenger sides will move down slightly enough to have a crack, if you repeat this process the windows will move down even wider.) i did this at 3 AM yesterday and i thought it was the coolest thing in the world, lol.
bring it back from the dead. atleast i searched! ! !
i recently bought a 96 se which has the keyless entry(tried the key thing, 6 times in and out and the hazards blinked).
i have two spare OEM Infiniti remotes laying around from my I30. The I30 now has an aftermarket alarm so the OEM remotes are no longer needed.
The question here is can I use the Infiniti remotes with the Max? I tried clearing the codes on thee remotes by removing the battery and pressing the lock button as mentioned above. i then put the battery back in and went outside and pressed the unlock button and its still unlocking the Infiniti. Is there a way i can completely reset the codes so it doesnt unlock the Infiniti or do I have to go out and buy actual Nissan remotes?
****forgot to mention that the remotes are from a 2000 I30****
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
please look in sticky called 4th gen how tos
