Aftermarket VQ35 cams in a VQ30 possible?
The only thing I can think of is people were saying if you use the nismo head for the 350z, you can't use aftermarket cams like nismo, tomei, or JWT. I think it was because of the titanium valves though. They would hit the cam or something.
Someone else said that tomei has their cams listed as VQ30 and VQ35.
Would it be worth it? In an older SCC they have the NISMO Tune 350z's and they show a gain of 10hp and 5ft-lbs of torque over the stock(has a dyno sheet). The claimed crank hp is 305. It has nismo intake, headers, cams, and exhaust along with other things totaling $48,264(stock was $34,180). They have suspension, wheels brakes everything in there. All that for .1sec faster time in 1/4 mile, .1 in 0-60, 73mph in a slalom(70mph stock), .95g(.93 stock), and braking distances in 80-0, 70-0, and 60-0 all WORSE by 10ft by just using nismo brake pads. Again I'm guessing it'll be different somehow on the vq30.
Originally Posted by slammed95
I believe some sort of shims must be used on the end of the cams made for VQ35's when going into a VQ30. The valvetrain looks a little different on each of my maximas. The VTC assemblies seem to add a little length to the space the cams take up on the cylinder heads.
I haven't disassembled the VQ35 enough to see the individual components to compare against my 95.
the other question is why would you want cams made for an engine with .5 more liters of displacement, totally different timing and breathing characteristics, not to mention higher compression?
Cam profiles are carefully and individually tuned to each motor.
As to whether or not they make power... well
http://www.my350z.com/forum/showthre...threadid=69913
SCC is full of it
SCC is full of it
Anyone have the NISMO VQ35 cam specs?
What could be different besides duration/lift?
Looking at the VQ30 vs VQ35 JWT cams, the VQ35s have about 4-degrees more duration and 0.4" more lift.
Someone explain?
Someone explain?
