6 hours C/V joint project
Old May 9, 2004 | 06:23 PM
Psubird83's Avatar
Anyone ever change there Passenger side C/V joint/drive shaft. A word to the wise, give yourself at least 6 hours too do it. I just finished up, this thing was a real pain in the arss. There is no room to work a ratchet or a wrench, and seperating the coupling, hah, that along takes 2 1/2 -3 hours alone. I'll post some pics when i get back from work tommarrow.
p.s. the only good news for the day is its done, works good, and it only cost me $60. =) not all frowns and busted knuckles
Old May 9, 2004 | 06:42 PM
subs1000w's Avatar
yeah those 3 bolts that hold the axle in are a pain to get at plus the axle is usually rusted into the mount
Old May 9, 2004 | 07:24 PM
DanNY's Avatar
Ad·min·is·tra·tor
woah 6 hrs...must be your 1st time. if/when it goes again it'll be 1000% faster.
Old May 9, 2004 | 07:58 PM
Cliff Clavin's Avatar
Way out West
yeah, when MrGone and I did my clutch, it seemed like we (well, mostly Shawn) had the axles out pretty fast. Of course with all the little things that happened with the tranny/clutch in the meantime, it took us until the next day to put them back in
Old May 9, 2004 | 11:38 PM
MrGone's Avatar
<- hates those 3 bolts, lol.
$60, Where did you buy it? (junkyard or parts store?) Just curious because I'll probably be replacing mine soon, and I cant remember how much they go for at Napa.
Old May 10, 2004 | 02:52 AM
Psubird83's Avatar
It was $60 dollars from Advance auto, it was also a rebuilt. And really the whole major problem was those three bolts, and seperating the coupling. And yes it was my first time. SO i guess i was a virgin to the whole C/V operation untill yesterday =/
Old May 10, 2004 | 05:00 PM
Bill Brasky's Avatar
Seperated at Birth?
Alldata gives you 2.5 hours for both axles. better start practicing!
Old May 10, 2004 | 09:26 PM
89maxSE's Avatar
the key to getting the PS axle out is to get those 3 bolts off then move the strut assembly and that crap out of your way so you can line the axle up straight..then just yank on it from there...i messed around w/ mine for sooo long then I tried that and it came right out w/ no problems.
Old May 11, 2004 | 07:49 AM
snowman2155's Avatar
I just put my passenger side axle in, those 3 bolts are a PIA.
Old May 11, 2004 | 11:54 AM
92se's Avatar
special tool
do you need the special tool to re - install the cv like the book says... thanks
Old May 11, 2004 | 12:12 PM
89maxSE's Avatar
nope...just push the bastard in till you feel it pop in all the way. shouldn't be all that hard
Old May 11, 2004 | 12:14 PM
92se's Avatar
thanks....
Old May 11, 2004 | 12:19 PM
3rdgenmaxima's Avatar
Did both sides this weekend, didn't take that long. And my friend and i were virgins to installing the cv axles too. It went smooth overall, except for those three bolts, man, wasn't too hard getting off but putting back on. I was so irritated took me over a hour to get them back on. That top bolt kept ****ing me off, but somehow i got it back on. But now the side my friend did the drivers side i guess we either got the wrong seal, or he didn't put it on right, cuz now im leaking like a **** load of that royal purple synthetic tranny fluid. Now i got to take the drivers side back apart and do it all over again.
Old May 11, 2004 | 12:38 PM
Jeff92se's Avatar
I'm needing a caw
You probably don't have it pushed in all the way. It will still function but if it's not pushed in, it will leak like a waterfall. lol
Old May 11, 2004 | 08:55 PM
corrupted's Avatar
i think nissan thought the would be funny and make those bolts so difficult ive delt with other couplings and they werent nearly as bad
Old May 12, 2004 | 01:42 PM
Jetman7060's Avatar
Are you guys talking about the three bolts that is sorta under the strut mount? They didn't seem too hard with a good breaker bar and some PB Blaster ;-) that's when I replace my clutch.
Old May 12, 2004 | 04:00 PM
lophix's Avatar
lol..dude, you have no idea. the bolts in question are right above the cross member in a very horrible position. I doubt any car has gotten as insulted as mine did when i was trying to change it.
Old May 12, 2004 | 04:57 PM
klymkow's Avatar
An air hammer works great to separate the bearing coupling.
The 3 bolts are much easier the second time around!
Did you put some anti-seize on the new axle to prevent it from rusting in place just in case it has to be replaced again?
Tim
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
