msd ignition
i have checked on the msd, msd told me the stacker 8 would work, then i call back to find them telling me nothing would work on our cars. i called several others vendors and they told me the same thing so i ended the search. as for as i know the msd ignitions wont work
Originally Posted by IwANnAMaX96
Our stock ignition systems are more than sufficient. There are ppl running over 400 WHP with no spark problems.
Originally Posted by Magikone69
well if we can run over 400 hp on stock ignition system does that mean upgrading the ignition will not give us any better performance? i was always curious when ever someone says our stock ignition is good enough. i mean the stock y pipe is good enough to help give the max 190hp but with an upgraded y pipe we can get so much more.
You're logic is pretzeled bruh...
You're looking at it the wrong way. An ignition system is not a power "adder" per se. You buy an upgraded ignition out of necessity, not because you want your car to be faster. Cause if that's what you're after, you'll be sorely disappointed. You buy a y-pipe to be faster. That's like saying you're installing a high-pressure Walbro fuel pump to add HP. It's completely unnecessary unless you're boosted, much like an upgraded ignition and even then, it would take extreme power levels to overcome the stock ignition.
I believe the HKS Twin Power ignition unit can be used on out car. To my knowledge it is the only system compatable with our DIS. The only person I know who has it is 1Max2NV, I have not read anything on it but I have seen a picture of it in his engine bay.
-Cyrus
-Cyrus
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
