89 max wont start
Old May 23, 2004 | 10:48 AM
duane3143's Avatar
89 max wont start
Hi, my 89 max SE cut off in the middle of the road. it had slight bucking before it died, and since than it will crank but never turn over. It has spark, and u can smell gas when i try to crank it
i tried replacing the distributor and cap, the coil, the fuses are all fine, and i tried to replace the computer (ECU) but it still wont work. What could possibly be the problem.. could it be a real dead battery? Would that cause it to cut off in the middle of the street?
Thanx in advance, i hope i can get it running
Old May 23, 2004 | 02:24 PM
4dscPat's Avatar
It's not the batter.
Oh snap, I hope you didnt break the timing belt.
Old May 24, 2004 | 06:38 AM
pedal2dafloor's Avatar
same thing happened to me before it was my ecu though. check all your belts make sure they are all on
Old May 27, 2004 | 08:58 AM
duane3143's Avatar
Ok... If the timing belt is off or broke.. wont it make some strange flapping noise when i try to crank it?
About the ECU... i got a replacement ECU from somewhere.. could it be that this one is bad too? How can i check to see if its a good or bad ECU..
I appreciate all the help.. i really need my car back
02PearlSE
Oct 7, 2015 02:12 AM
neilraz
Sep 11, 2015 07:36 PM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
Balkins
Aug 12, 2015 06:39 AM
