keyless entry programming difficulty
Old May 27, 2004 | 12:46 PM
LTD99's Avatar
I just purchased a used 95-99 remote entry (FCC ID: A269ZUA079) along with programming instructions. the instructions say to:
1: lock all doors and sit inside car
2: insert and remove key from ignition 6 times within 10 seconds
this causes a blink in the dashboard lights which allows proceeding
turn switch to "ON" and press any button on the remote and it should work
BUT..... i never see the blink of my dashboard lights no matter how i instert the key
if i do it 100 times within 60 seconds i still see no light. i have a 99 SE LTD and was wondering what i was doing wrong... i would rather not pay a dealer $40 for this since i just lost my job. is there a specific trick to inserting the key? anyone have experience i would appreciate it.
Old May 27, 2004 | 01:23 PM
njmodi's Avatar
Do I get a tax break?
Do you have a remote that works right now? or is this your first remote...?
Try the procedure here:
http://home.earthlink.net/~maxfaq/
Under the Maintenance Section - Programming the Keyless Remote.
Old May 27, 2004 | 02:11 PM
LTD99's Avatar
[QUOTE=njmodi]Do you have a remote that works right now? or is this your first remote...?
*I have no remote currently
*This is the same instructions i followed, still nothing. is 99 se ltd compatible for sure?
Old May 27, 2004 | 02:20 PM
Matt_NZ's Avatar
Are you sure your car has the keyless entry option? If you've never had a remote for the car until you got this second hand one, chances are it doesn't have it Even if you have the alarm, it does not mean you have keyless entry.
Old May 27, 2004 | 02:30 PM
LTD99's Avatar
Thanks, you are probably right. The owner never gave me one when i bought it.
Old May 27, 2004 | 02:41 PM
todd99se's Avatar
I have the same problem with keyless entry
I have been going throught the same problems and my dealer has been no help. I even took it by one day and the Service Advisor told me that one of my door latches was bad so I replaced it and still nothing, I can not get the hazards to flash. Is there a way to tell if the vehicle has RKE (remote keyless entry)or not??
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
jcvgn
Sep 10, 2015 08:03 PM
Hailstatejig
Sep 2, 2015 06:52 AM
