Emanage Help ( And Future Faq )
Old Jun 30, 2004 | 10:15 PM
h2kFrosty's Avatar
Can I get some help to jumpstart my emanage install?
Specifically I would be looking for what rotary switch settings to use and a pinout or any help on ecu wires
I intend to run the ignition and injector harnesses... and have seen the posts about frying coils. Can I wire a resistor in and be ok? Specifics please on the ignition wiring & hookup.
Old Jul 1, 2004 | 04:14 AM
JAY25's Avatar
If you want to hook up some of those wires you can bring yo azzz down to NO. Ill be there sunday and possibly monday. So if you guys want I can help you and Barbee Q chris, with some of that/walk you thru it etc.....Do you guys read the SE section? ignition that your on your own, I dont have that just the injector harness. Be ready to have some back aches or remove the passenger seat
Old Jul 1, 2004 | 06:59 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
you aint lying!!!
the pin-out and rotorys should be the same as the 99, 7-0-1
you'll need diodes wired in-line on the ignition harness to prevent burning the coils...you'll have to contact Dixit, he knows the part #s and sent me and Redmax them when we did his Emanage. you won't be able to advance timing with this method, only retard, but thats the most important for our application anyways
Old Jul 1, 2004 | 10:38 AM
Ramius83
Quantity (6) of 1N55200 Diodes, from RadioShack.....White band on diodes facing towards the coil-packs....
Old Jul 5, 2004 | 12:50 AM
HNDA ETR's Avatar
Still Here... IM me for more..
PM BigDogJonx... I think he was able to get the ignition harness working...
Old Jul 12, 2004 | 06:41 AM
studman's Avatar
FYI:
Firmware 1.39 has been released. If you are a VQ30, your dial settings should be 7-0-1. If you are a VQ35, you need to change from 7-0-1 to 7-0-B when you upgrade to 1.39 or higher.
If you have the PC Support Tool, you can download the upgrades from http://www.mohdparts.com/ in the E-Manage section.
Maxboy23
55
May 1, 2025 06:09 PM
Maxboy23
Sep 9, 2015 10:37 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
