what is absolutely the best oil stop leak?
Are you getting a leak or is the oil being burned normally? I noticed that you can lose oil into your intake system. This is the reason I'm going to install a oil catch can just ot see how much I lose.
how much oil do your cars lose b/w oil changes?
I ask this b/c I'm looking at a 98 max SE (91k) and the owner says it burns a qt. of oil b/w changes, and that it's done this since he got it. I saw no evidence of burning oil on the car or a drip in the driveway, but these are things that can be covered up.
I never burn a drop...the transition between 5W and 10W between winter and summer I tend to burn a little but thats only 1/4 of a qt maybe...I will see if Im still burning after the next change
engine is safe at 1qt per 1000 miles according to VW...Our jetta burns alot but doesnt exceed that amount
-matt
-matt
To answer the original poster, I would personally not put an oil leak stop in my engine. I wouild use a high mileage oil before doing that. The reason is that they have balanced the oil properly with their own stop leak instead of throwing in "Freddie's Super-Stopper!" on top of your regular oil. Valvoline is one of the companies that has a high mileage oil. You could give that a go.
Other than staining the driveway, I think that a mild oil leak is not worth worrying about. I went through 30k miles on my 93 sentra with that, before getting rid of it recently. The repair was a $500 rear main seal replacement. I just kept an eye on the oil and lived with it. It never seemed to get all that much worse.
Here is a link for you. This stuff works and is not snake oil.
http://www.auto-rx.com/
http://www.auto-rx.com/pages/sealleak.htm
If you decide to buy the stuff, join their forum section to receive a member discount.
That is quite a bit of oil to be burning with only 91k...I would get the compression checked out before you buy it.
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
ag90fox
Sep 9, 2015 12:22 PM
