One or two step colder?
Old Jul 27, 2004 | 09:52 PM
jcy98maxse's Avatar
Turbo is too much fun!
Which step plugs should i get for a 75 shot? I read on Jime's site that he recommends 2 step colder. On the org, ppl have said one step colder? Plus does it effect performance in anyway running N/A with colder plugs(especially 2 step colder) as a daily driver?
Old Jul 28, 2004 | 04:57 AM
SonicDust187's Avatar
I would run 1 step colder. I ran 2 step colder before and I noticed a diff. when I went to one step colder. I am sure I am still missing some power NA.
Old Jul 29, 2004 | 07:11 PM
ajsince81's Avatar
The guy I talked to at NX recommended running 2 step colder for a 75 shot. However the guy I talked to at NGK, when I was trying to get the correct plug for my car, said to use 1 step colder for a 75 shot. So i don't know. I went with the 1 step colder for my car and everything seems great.
Old Jul 29, 2004 | 11:54 PM
jcy98maxse's Avatar
I am thinking I'll go one step colder for now because I won't be doing 75 shot all the time (ie everyday) so I dont want to be suffering just being N/A (with 2step colder plugs)
Old Aug 1, 2004 | 09:35 PM
MaxSpeedSE's Avatar
Im one-step colder with the 100 shot for a while now... and no problems but im doing other things for protection.
Old Aug 2, 2004 | 01:33 PM
Like what?
Old Aug 2, 2004 | 02:07 PM
MaxSpeedSE's Avatar
Originally Posted by SonicDust187
Like what?
Ive already told you
Old Sep 29, 2004 | 09:54 PM
akadiablo's Avatar
colder spark plugs
what is it i should get for spark-plugs.. I am running 50-75 shots of nitrous from a zex wet kit... I am wondering what spark plugs i need to get to do so ....... NGK, other brands???? Just let me know ....
Thanx, All....
Chris
Old Sep 29, 2004 | 11:54 PM
jcy98maxse's Avatar
I think NGK coppers are the way to go. One or 2 step colder, its your preference...
Old Sep 30, 2004 | 06:12 AM
Jime's Avatar
I would use 2 steps if you are planning on running a 100 shot or higher, otherwise 1 step is sufficient.
Old Oct 1, 2004 | 08:54 AM
RichP23's Avatar
How much N/A power is taken away when running 1 step colder plugs?
Also, I'm looking to get an S-AFC. Is anyone running this with Nitrous? Would there be any negative effect with the S-AFC when going from N/A to Nitrous?
Thanks.
Old Oct 1, 2004 | 09:12 AM
Jime's Avatar
Thanks.
I don't notice any difference in the 1/4 with 2 steps colder but some say there is.
If you get an SAFC-II it has 2 settings, so I use one for N/A and one for nitrous. The original S-AFC has only one so you would have to change it going from N/A to spray.
Old Oct 3, 2004 | 04:42 PM
maxima98vspec's Avatar
justin i put in my 1 step colder coppers and didn't really feel much lose, maybe a little but but nothing big, i went with 1 step for now with 50 shot but we'll see how that goes.
Old Oct 3, 2004 | 05:12 PM
Ive been running 75 shot on one step colder without a problem. Soon going to 100 shot on one step colder. I will be watching that egt really closely. However, at this time I am having problems with my egt gauge.
Old Mar 22, 2008 | 11:54 AM
mastercater7's Avatar
VQ35 FTW
Someone help me out here, can I run a 75 shot on stock plugs on a 4.5 gen? and if not, are the 3.5l plugs and 3.0 plugs the same when the 3.5 is on 3.0 timing?
Old Mar 22, 2008 | 01:36 PM
Jime's Avatar
I would use at least one step colder. 3.5 and 3.0 plugs are totally different, they have a different reach and you must use 3.5 plugs regardless of the 3.0 timing etc.
Old Mar 22, 2008 | 03:04 PM
jcy98maxse's Avatar
Holy old thread!
Old Mar 27, 2008 | 11:50 AM
Deckdout2's Avatar
Play with my balls
Originally Posted by jcy98maxse
Holy old thread!
Batman.
Old Apr 3, 2008 | 02:49 PM
punjabi's Avatar
As far as i know 1 step colder shoud be fine. If i was you i would also get a window switch just in case u miss or trann fales and possible do a dyno run w/ afr just so you know you afr. Thats just my opinion tho.
Old Apr 6, 2008 | 05:59 PM
Revs2Hard's Avatar
BARF
On a 75 shot I ran 1 step colder and that worked great. Now Im running 2 steps colder :-)
gigabyte
Jan 6, 2017 06:05 PM
JoshG
51
Sep 21, 2015 10:41 PM
thenewguyy
Sep 12, 2015 11:12 AM
