Sponsored by:
Sponsored by: CARiD
3.5 in a 4th gen
Old Aug 2, 2004 | 08:09 AM
emmas97's Avatar
3.5 in a 4th gen
ok i am tilleys99's gf and i just bought dex's 97 max.... we want to put a 3.5 bottom end in my max and i just wanted to know if anyone has attempted this besides tilley.... thanks
Old Aug 2, 2004 | 08:23 AM
emmas97's Avatar
yeah he already has the motor, which he was gonna throw in his max, but he needs rods and a flywheel and an intercooler yet, so he is just going to run his 3.0's til they blow up... i want a fast all-motor max, he can turbo his and it will be all good lol.... and congrats on your babies...well when they come... they are a handful but def worth it cause they grow up to adore you and idolize your every move (which isnt always a good thing) good luck with them
Old Aug 2, 2004 | 11:33 AM
Jason R's Avatar
aka UNCDooD
only other person attempting to put a 3.5 bottom end in there 4th gen is MardiGrasMax. He said he hopes to be have her running sometime at the end of the moneth.
Old Aug 19, 2004 | 03:01 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
well the motor is all together just waiting on headers to install it, heres a run down on it.
3.5 bottom end
3.0 head (vq30DET)
jwt cams
obx headers
Old Aug 19, 2004 | 03:14 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
3.5 bottom end
3.0 head (vq30DET)
jwt cams
obx headers
just wondering, if you're going through the trouble of installing a 3.5 bottom end, why not swap the whole thing?
Old Aug 19, 2004 | 05:08 PM
Pimpmobile's Avatar
I brought up the VQ33DE stroke while the org was down over on max-world. Apparently the stroke from the 3.5 crank will push the pistons through the heads (according to some one) I don’t think this is the case. The VQ35DE is the same block but bored and stroked to get to the 3.5L mark. I plan on getting all the specs on both engines and see if this is true. orrrrr... some one could spare me and my mechanics time and post the info about the 3.5 crank and relation to 3.0 rods etc etc.
I know the mains are the same (.: plug and play) but the journals may be different and require different rods. If the journals are not compatible with the 3.0 rods the whole project would be a waste of money.
Another possibility is to use the 3.5 crank and rods with 3.0 pistons, since the VQ30 block cannot be bored out enough for the 3.5 pistons.
feedback is welcome... wanted
Since I only have vq30de manuals I can only provide the specs for it, I think this is all the relative information, so if some one with a VQ35DE manual could post a corresponding specs.
VQ30DE
Displacement; 2,988cm
Bore x Stroke; 93 x 73.3 mm
Comp; 10:1
Pistons
Piston pin hole diameter; 21.987-.999 mm
Piston pin outer diameter; 21.986-22.001mm
Connecting rod
Center distance; 147.60-147.7mm
Piston pin bushing inner diameter (installed); 22.000-22.012mm
Connecting rod small end inner diameter; 23.980-24mm
Connecting rod big end inner diameter; 48-48.013mm
Crank
Main journal diameter
Grade No. 0 59.969-59.975mm
Grade No. 1 59.963-59.969mm
Grade No. 2 59.957-59.963mm
Grade No. 3 59.951-59.957mm
Pin Journal Diameter
Grade No. 0 44.968-44.974mm
Grade No. 1 44.962-44.968mm
Grade No. 2 44.956-44.962mm
Center distance; 36.61-36.69mm
Old Aug 19, 2004 | 06:43 PM
i30ds's Avatar
Armed and Dangerous
VQ30DE
Comp; 10:1
Pistons
Connecting rod
Crank
There was one member that did the 3.3L stroke by simply droping in the 3.5L crank and rods. According to him, the fit was exact and no modifications were needed. Everything else was from the 3.0L. He had pics so.....
Old Aug 20, 2004 | 08:03 AM
Pimpmobile's Avatar
do you remember his name?
But according to SR20DEN it wont work (oh my dreams of a all motor 4thgen are dashed *cry*).
Old Aug 20, 2004 | 09:28 AM
TILLEYS99's Avatar
well its all together and spins with no issues
Old Aug 20, 2004 | 10:36 AM
Pimpmobile's Avatar
Tilley, you did a VQ33 stroke, and it all worked?
Old Aug 20, 2004 | 03:29 PM
Pimpmobile's Avatar
I wish we could all agree, Tilley is saying it works SR20DEN is saying it doesn't.
Tilley, does it fire up and run ok?
Old Sep 8, 2004 | 03:15 PM
TILLEYS99's Avatar
in and running and oh so sweet it is
Old Sep 8, 2004 | 06:00 PM
vsamoylov
i was kidding guys. the vq35 is in my car and it is runningg also. the only thing that is keeping me from driving the car is some wiring and waiting for my intake from frankencar but they are not rersponding to me at all.
Old Sep 8, 2004 | 08:40 PM
THT's Avatar
THT
Throbbing member
Yeah, it was Dixit. I don't think he ever turned the car over though...just dropped it in to see if it would fit.
~THT
Old Sep 9, 2004 | 05:51 AM
TILLEYS99's Avatar
I could give pics but the only things visible are a hai, udp and headers
Old Sep 9, 2004 | 02:06 PM
BluFlame's Avatar
Where did this 3.5L engine originate from? 03 or 04 max?
Old Sep 9, 2004 | 02:50 PM
TILLEYS99's Avatar
02 max
Old Sep 9, 2004 | 05:23 PM
1FSTMAX's Avatar
Has anyone thought of doing a vq35 bottom end with 2k-2k1 heads, and a VIAS? I've been contemplating that for a while now.
Old Sep 9, 2004 | 05:52 PM
Larrio's Avatar
The Definitive AE Master
hmm.. which flywheel, clutch, tranny, etc? Which ECU are you using and how is it running?
Old Sep 9, 2004 | 06:24 PM
krismax's Avatar
Father of the 00 VI
What im going to do IF i do this is ,just use my 96 heads with the 00VI. On the 3.5 block with aftermarket internals so i can keep my 8000rpm redline
Old Sep 10, 2004 | 05:55 AM
TILLEYS99's Avatar
stock ecu, competition clutch flywheel, centerforce dual friction clutch (was in car prior and was in excellent condition till the 3.5 got a hold of it), stock lsd 5spd, obx headers, udp, jwt cams, vq30det heads, with 3.5 headgaskets.
Old Sep 10, 2004 | 06:52 AM
Larrio's Avatar
thanks for the info! so basically everything on the car is still from a vq30de (tb, flywheel, udp, ecu) except the vq35 short block, gasket and vq30det heads?
Old Sep 10, 2004 | 08:44 AM
Sprint's Avatar
I was gonna call you dex. Since it was originally your car maybe we will let you take it for a spin. BTW do you remember when I put that clutch in and how many miles were on the clutch cause its slipping some.
Rob centerforce sucks.. they start slipping after 10k miles
Old Sep 10, 2004 | 09:33 AM
TILLEYS99's Avatar
I noticed they suck i have installed them in a bunch of cars and had no problem.
Old Sep 10, 2004 | 10:57 AM
DAVE Sz's Avatar
Hooooooonda.....
From what I read you'll want to get rid of the cams ASAP.
Old Sep 10, 2004 | 11:02 AM
Jeff92se's Avatar
I'm needing a caw
What are the difference inbetween the normal VQ30 heads and the VQ30DET heads? Combustion chamber different??
Old Sep 10, 2004 | 12:09 PM
TILLEYS99's Avatar
Why would i want to get rid of the cams they are awesome and give nice high rpm power, if there is anyone out there sayin they suck they are not doing something right or maybe you just think they are bad cause only a few people have em.
Old Sep 10, 2004 | 01:00 PM
DAVE Sz's Avatar
Hooooooonda.....
Well there is someone with them. He has no power until like 4k rpm. Below that his car is barely moving. The again he has them in his 3L.
Old Sep 10, 2004 | 04:51 PM
vsamoylov
VQ30DET? nissan made vq30 only in 4th gen maximas. where did you get the vq30det from? and how much in the end this cost you? and do you think it will make more power and get better numbers than a vq35 engine? i think just doing a complete vq35 swap is easier than having to tear the engine down and getting up a buch of parts without knowing how they will work together. what kind of compression because those eningines will not run high compression on regular gas. that is what i think.
Old Sep 10, 2004 | 05:09 PM
krismax's Avatar
Father of the 00 VI
Look at this. http://www.vq35de.com/EngineSpecs/Ni...neSpecs.htm#VQ
And i dont know whats harder to do but i would say what your doing is harder because he's driving around and your not
Old Sep 10, 2004 | 09:05 PM
emmas97's Avatar
the heads are jdm, im not up to date on this but somewhere in japan they made a vq30det.... the original plan was to put the whole 3.5 in tilleys max but then i bought mine and, well new ideas formed cause i like all motor.... he got a deal on the whole motor and 6spd tranny (which is in his max) the cams cost 1100 and he had the heads so when he reads this he can tell you more costs... and compression is 11.5:1 and it runs fine on 93.
Old Sep 12, 2004 | 12:16 PM
vsamoylov
so looks like just doing the same swap as me is the cheaper way. i picked a 2k2 max for parts for $1550. and my car is not driving right now because i did not get my frankencar intake yet. and still no pics of the swap at all. didnt you take pics while doing the swap? i took a huge amount of pictures cause it is one of a kind .
Old Sep 12, 2004 | 03:43 PM
emmas97's Avatar
sorry no we didnt take pics during the swap. the engine was in and out in ten hours, no time for pics
Old Sep 12, 2004 | 05:50 PM
flashover's Avatar
Originally Posted by DAVE Sz
What's a lower manifold?
It is the lower intake manifold, where the fuel injectors/ fuel rail is bolted onto.
The lower manifold itself is bolted directly onto the cylinder heads.
Old Sep 12, 2004 | 06:21 PM
JClaw's Avatar
How about dumping a whole VQ35 in a 3rd gen? Would that technically work? I mean, getting an old 89 or 90 for 1.5k would be less costly than a 4th gen.
Old Sep 13, 2004 | 08:05 AM
Sprint's Avatar
you are misinformed and should do some more research.
oh really now
VQ30DET is an engine created in 1995 and is featured in the Nissan Cedric and Gloria in Japan. At 5.5 PSI the motor puts out 280 hp and 285 tq.
If you like playing with wires and ecu maps with both FSM then yeah .. go right ahead.
maxima's have no problems running high compression, the stock compression of the VQ30DE is 10:5:1, people have been running boost as high as 14 PSI with 93 octane and have had no problems. I think the VQ30DE can running 12:1 compression without a problem on pump gas, but how would you know this? You don't have a boosted car or a high compression NA Car.
FYI the VQ30DET comes with 9:1 compression
Old Sep 13, 2004 | 09:21 AM
TILLEYS99's Avatar
I just ordered my metal to make a sheet metal intake manifold. Im hoping for good gains with it if so i may mass produce it
Old Sep 13, 2004 | 02:24 PM
TILLEYS99's Avatar
If you cant take it apart and do internal work you may as well keep it stock. its a cool swap for you with the 3.5 complete swap but thats just too simple and boring. I am in to doing that off the wall odd ****, just wait till i find a 05 frontier vq40de then its on for my max (which is turbo 6spd) this all motor is my girls
Old Sep 13, 2004 | 02:36 PM
Sprint's Avatar
hey Rob..
Old Sep 13, 2004 | 02:54 PM
TILLEYS99's Avatar
no just valves retainers and springs supposedly
