opinions and comments..hmmm
Old Aug 5, 2004 | 12:19 PM
MISTER BIG's Avatar
what do you guys/girls think my problem is....
(i believe its either glazed clutch disc/flywheel, or some engine/tranny mounts)
when accelerating from stopped position, i get clutch chatter, if i take off with higher rpm's (1500+RPM) chatter gone... also, when i down shift, it also occurs... it also happens when reversing..
i tried setting the e-brake and putting it in first, and revving it,, i seen maybe 1" movement...like where the intake plenum is,,,,
im hoping its not my clutch, if its a mount, which one do you think would cause that...
Old Aug 5, 2004 | 12:20 PM
Jeff92se's Avatar
I'm needing a caw
Get under there and check the mounts
Old Aug 5, 2004 | 12:28 PM
MISTER BIG's Avatar
and how can you tell....
pry bar maybe?? visually how do i know? other than an obvious situation ofcourse..
so you dont think
Old Aug 5, 2004 | 12:30 PM
MISTER BIG's Avatar
so you don tthink its the clutch from my description
Old Aug 5, 2004 | 12:31 PM
Jeff92se's Avatar
I'm needing a caw
Move them a bit and inspect for cracks/rips in the rubber.
It could be a glazed clutch but then again you have not told us your driving style, type of clutch nor how many miles on the unit.
Old Aug 5, 2004 | 12:33 PM
MISTER BIG's Avatar
driving style...quick shifts, peeling out every so often, hard down shifting... hmmmmmmmm... ill start saving for that clutch .... =P
thanks, ill check those mounts weekend time
Old Aug 5, 2004 | 12:42 PM
Matt93SE's Avatar
STFU n00b!
you most likely need new engine mounts. that will cause the chatter to get worse, if it's already there.
you probably should be a little nicer to the clutch as well if you expect them to last more than 20k miles on a clutch. (don't ask how I know)
Old Aug 5, 2004 | 12:52 PM
MISTER BIG's Avatar
you brought up a good point matt, i just realized ive had mycar for over 100K km's (bought the car used) how long is a clutch supposed to last with normal people driving. haha
REDinLV
Aug 15, 2024 12:30 AM
dvcamp
Sep 18, 2015 10:17 AM
ac max 92
Sep 17, 2015 07:35 AM
