opinions and comments..hmmm
what do you guys/girls think my problem is....
(i believe its either glazed clutch disc/flywheel, or some engine/tranny mounts)
when accelerating from stopped position, i get clutch chatter, if i take off with higher rpm's (1500+RPM) chatter gone... also, when i down shift, it also occurs... it also happens when reversing..
i tried setting the e-brake and putting it in first, and revving it,, i seen maybe 1" movement...like where the intake plenum is,,,,
im hoping its not my clutch, if its a mount, which one do you think would cause that...
you most likely need new engine mounts. that will cause the chatter to get worse, if it's already there.
you probably should be a little nicer to the clutch as well if you expect them to last more than 20k miles on a clutch. (don't ask how I know)
REDinLV
10-18-2015 05:31 AM
dvcamp
09-18-2015 10:17 AM
