Question about ECU's 95-99
Old Aug 30, 2004 | 02:30 PM
x8ver
Question about ECU (computer ) on 1997 gxe 5speed...
Or question really is I have a 1997 gxe 5 speed what years can I replace with??? Is it only 97-99??? or does it have to be strictly a 97 5 speed. Also why does it matter 5Speed or Automatic ECU (computer). They installed a automatic ECU and its making my revs bouncy still runs but shaky and bouncy???
Thanks...
Old Aug 31, 2004 | 11:33 AM
x8ver
direct question
directly can I use a 1995 ECU 5speed stock in a 1997 5speed will it be compatible....that is simply my intentions will it work or not???????
thanks...
Old Aug 31, 2004 | 12:12 PM
DpG $h0rTeE's Avatar
yes but with a possible CEL. I have a 95 ECU working in my 98.
Old Aug 31, 2004 | 12:34 PM
chuckie311's Avatar
you can also use a 96 ecu in your car
Old Aug 31, 2004 | 01:21 PM
SPiG's Avatar
SomePsychoGuy
You can use any 95-98 ECU in any 95-98 maxima. Some will get SES lights while others won't but they will all run. Only 95-96's can be reprogrammed at this time, so 97-98 ppl need to buy a 95-96 ECU to be reflashed by TS or JWT. I believe some 99s with some wires swapped can also use the 95-96 ECU as well.
I know you can install an auto ecu in a manual car and you may have some extra codes, but I am not sure about installing a manual ecu in a auto car. There is a much larger supply of auto ecus anyway.
Old Aug 31, 2004 | 03:39 PM
chuckie311's Avatar
i have been trying the 96 ecu in a 99 and im not having any luck. even with the wires swapped.
Old Sep 1, 2004 | 11:10 AM
SPiG's Avatar
SomePsychoGuy
Yeah I was not sure about that one. I think the 99.5's may have a 5th gen ecu maybe. I am not really sure. I just remember that someone saying that with a few wires that at least SOME of the 99s could use a 95/96 ecu. Maybe once TS comes out with 00-01 ECU you may be in luck. I will search around for the thread talking about the wires to swap. I think JWT may be able to work around the 99 differences as well and make it work. Call JWT, they may know more.
Old Sep 1, 2004 | 11:13 AM
SPiG's Avatar
SomePsychoGuy
http://forums.maxima.org/showthread....&highlight=ecu
http://maximaracing.org/viewtopic.php?t=1017
JWT supposedly can get a 95-96 ECU to work with a 99.
Old Sep 1, 2004 | 11:23 AM
Digital's Avatar
VIP
JWT would have an answer for you, I 2nd that from h2kSPiG
Old Sep 1, 2004 | 11:44 AM
chuckie311's Avatar
i have called jwt and they are not sure but they thought it was the fuel pump pin also. im working with a enginerr for nissan and he is going to see what has to be done for it to run in the 99...
Old Sep 1, 2004 | 03:35 PM
96pearlmax's Avatar
How did you fry your first ECU??????????
Old Sep 1, 2004 | 03:41 PM
Kevlo911's Avatar
Kevlo for President
I have posted this in many threads, Chuckie, Have you dissconnected the immobilizer yet?
Old Sep 1, 2004 | 03:45 PM
x8ver
if the question is to me...
Be aware of the Service Bullentin it happened to my 97 the water backed up in the A/c tube and water started coming inside and wet the ECU and it went crazy till it didnt start the car anymore. Their is bullentin that the underneath the wipers leaves & dirt gets caught in there and clogs up where the condensation came inside the car. Sucks bigtime....
Old Sep 1, 2004 | 04:41 PM
chuckie311's Avatar
i have post this many times the immobilizer has nothing to do with it in the 96 ecu . even jim wolf said so also
Old Sep 1, 2004 | 05:34 PM
Kevlo911's Avatar
Kevlo for President
Yes, but you have said the security light stays on when you are turning on hte car which means the immobilizer system is activated, it wouldn;t hurt to try and dissconnect it.
Old Sep 2, 2004 | 11:39 AM
x8ver
I appreciate all the help
thanks
Old Sep 2, 2004 | 07:59 PM
joew's Avatar
I have unplugged the gray connector on the ECU. do you folks know how to pop off the white plastic box? i need to open it.
http://memimage.cardomain.net/member...68_20_full.jpg
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
