I might have a problem...
I was turning into a parking spot today and clanking sound came from what seemed to be my front driver side strut. I tried reproducing it and it would only happen when my wheel is turned extreme left and I was accelerating. What do you guys think this could be? Spring unseated, blown struts, etc?
It's a CV joint, almost certainly. That's a pretty textbook sound that a busted one makes AFAIK. Replacing it entails replacing the axle on that side, I think. At least that's what the guys on "two guys and a garage" did on the weekend
It does sound like the cv joint, but I'd be surprised if the boot was already ripped on your 03. Go into an empty parking lot and turn the wheel all the way to the left and do some slow circles. Try it turning to the right and doing the same. If you hear a knock.... knock... knock, it is probably your cv joint. Look underneath the car on the affected side and look at the boot right before where the axle meets the wheel. If the boot is ripped, the cv joint needs replaced.
any way to discern between a problem between the strut bearing and a CV boot?
I'm not so sure that its my CV boot b/c my max is relatively new. 36k miles. What makes me more suspicious of the strut is that it wasn't installed well and I had to redo it a couple of times.
Originally Posted by charliekilo3
A busted (dry) CV joint will normally be nosiy at all times the wheel is moving.
My CV joint needs to be replaced soon and it only clicks when the steering wheel is turned completely to the right. During normal driving theres no clicking.
Originally Posted by NuJerseyDrive
Do you mean the steering wheel or the actual wheel (tire)?
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
