Gle Door And Shifter Wood Trim
Old Apr 8, 2001 | 10:47 AM
roy's Avatar
roy
HAS ANY ONE REPLACED THE DOOR AND SHIFTER TRIM ON THE SE WITH THE STOCK GLE WOOD TRIM, IF SO HOW IS IS IT DONE. NOT SURE ON HOW TO DO IT. IF YOU HAD THE DEALER DO IT , WHAT WAS THE COST.
Old Apr 8, 2001 | 11:31 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
There's a wood dash kit that goes over those pieces... check out the parts list thread at the top.
BTW, use lower case when typing because it looks like you're screaming at us.
Old Apr 8, 2001 | 11:39 AM
mdeal's Avatar
I can say the shifter surround part is removed by gently prying up along the corners furthest from the radio, then you work your way up until you can get yours hands on it and remove it.
Old Apr 8, 2001 | 02:39 PM
mregenst's Avatar
CAREFUL-CAREFUL:
Go easy, I have a GLE & wanted the lighter kit installed, have two left hands, didn't want to bugger anything up, so had the dealer do it...thank goodness they quoted a firm price for installation-half hour, cause it took one and a half hours, gently prying the wood trim off to install the components...go very easy with this...otherwise you'll be sorry....
Old Apr 8, 2001 | 02:41 PM
roy's Avatar
roy
[QUOTE]Originally posted by mdeal
[B]I can say the shifter surround part is removed by gently prying up along the corners furthest from the radio, then you work your way up until you can get yours hands on it and remove it.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
Redfox
Sep 28, 2015 10:41 AM
