engine ticking noise - *video*
Old Sep 24, 2004 | 04:29 PM
bruteMax's Avatar
Key in 'On' position, something in the engine is constantly ticking. When idling it's still ticking but you can barely hear it over the noise of the engine.
Any ideas of what it can be and if it's something I should be concerned about? No codes from the ecu.
I'm halfway through my maximizer install so forgive the wires sitting ontop of my airbox.
right-click save as
Old Sep 24, 2004 | 04:38 PM
mzmtg's Avatar
Minister of Silly Walks
Wow, that is really wierd.
Sorry, I have no idea what that could be. Kudos for going straight to the vid though!
Old Sep 24, 2004 | 04:47 PM
sunten1
lol its a TIME BOMB!!!
Old Sep 24, 2004 | 04:48 PM
fisher01's Avatar
Strangest sound I ever heard. Definitely think something is wrong. I'd take a hose, use it like a stethascope, and see if you can determine exactly where its coming from.
Old Sep 24, 2004 | 04:49 PM
MDeezy's Avatar
not normal.
Wow, that is not normal at all.
Not too sure what that is, but I think it must be something electrical, since nothing mechanical is moving.
The ticking seemed strong towards the firewall, toward the passenger side.
Old Sep 24, 2004 | 04:52 PM
RA030726's Avatar
I'm nutty for Nissans
i think it is the iacv or something around that area having to do with emmisions, I think my car makes the same sound but much quieter, you have to be right up close to the thing to hear it. almost as quiet as an injector.
Old Sep 24, 2004 | 05:35 PM
s0ber's Avatar
Its some weird thing, I remember at a maxima meet down here in florida some guy had the same problem with the ticking... Something about the IACV as well.. Not sure, might wanna take it out and clean it???
Good luck, let us know what it is
EDIT: I just saw the video, it sounded nothing like that..
soundslike a cLOCK...
Can you pinpoint where the sound is coming from exactly?? Sounds like a broken relay but there not even that loud...
Old Sep 24, 2004 | 06:15 PM
maximus_pr's Avatar
is this for real
did you check for codes if something is bad enough to make a noise so loud it is for sure is gonna trip a code also a saw a n/x sticker you running nitrous check for a bad solenoid ar maybe a relay there's relay box next to timing chain cover
Old Sep 24, 2004 | 06:54 PM
Rowan's Avatar
it's a mouse
no freaking idea. sorry
Old Sep 24, 2004 | 07:20 PM
maximus_pr's Avatar
it sounds like when a/c clutch engages but it won't do it unless you turn car on i think you better take your car check for any electrical problem
Old Sep 26, 2004 | 08:32 PM
qboc2's Avatar
Sounds like the timing chain, or chain tensioner. I had the same problem two years ago when the milage hit 150k.
Old Sep 26, 2004 | 08:40 PM
s0ber's Avatar
Sorry, but I think the car would need to be on for it to be the timing chain tensionor.
Old Sep 26, 2004 | 08:50 PM
maximus_pr's Avatar
try disconnecting relays one by one until noise dissapear
Old Sep 26, 2004 | 08:58 PM
I30tMikeD's Avatar
$5 I know what it is. Check the screw on your ECU and make sure it is not turned clockwise or left in the middle. It needs to be all the way counter-clockwise.
......I think it's counter clockwsie....either way you will know once your looking at it.
Old Sep 26, 2004 | 09:03 PM
DAVE Sz's Avatar
Hooooooonda.....
I know that if you have some sensors disconnected the car sounds like that. If you disconnect the brown connector from the TPS it sounds like that or similar. I don't know since your video doesn't work.
Old Sep 27, 2004 | 06:38 AM
bruteMax's Avatar
Well Maxima10to1 is right, it was the iac valve. I pulled the connector off and the ticking stops. I'm going to follow the steps in the FAQ to clean it or perhaps the fast idle solenoid needs replacing. Either way I'm just glad the problem has been identified.
Thanks for all your suggestions.
Old Sep 27, 2004 | 06:53 AM
I30tMikeD's Avatar
Please go check your ECU screw.
Old Sep 27, 2004 | 06:57 AM
I30tMikeD's Avatar
http://forums.maxima.org/showthread.php?t=243052
the thread is about two seperate problems....ignore the misfire problem.
Old Sep 27, 2004 | 07:02 AM
I30tMikeD's Avatar
and this one as well
http://forums.maxima.org/showthread.php?t=254429
Old Sep 27, 2004 | 09:40 AM
bruteMax's Avatar
Thanks Mike,
My ecu screw keeps turning counter-clockwise (never stops - guess it's broken), so I just turned until I felt some resistance. At that point the ticking did stop. CEL came on, going to scan it when I get back form work.
So I guess the question is, why does leaving the ecu screw in a position other than full-cc trip the iacv? And as you had asked in your 2nd thread, I wonder what other impact this may have had on the car's performance?
Thanks again,
Bill.
Old Feb 24, 2005 | 06:53 PM
eturnl
im just posting to save this thread for me for later hehe
spazma7ik
Jan 12, 2017 09:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
