anybody had probs w/underdrive pulleys? n/m
Mine started leaking after a year -- sent it to ASP, had the collar machined on, and no more leaks! As for a drop in alternator current, I don't run a big system at all so I have seen no ill effects in that regard.
"no message". commonly used on forums like www.z31.com so that they don't look at it and find that there is no message. there are seperate pages for the individual replies unlike having all of the replies on the same page like it is here.
Originally Posted by blacks92seAuto
is it possible to buy a metal collar to machine onto the pulley yourself? ....I ordered a pulley for my car, and its already on the way...never thought about getting a metal colar on it.....is there anyway i can take the pulley once i get it and have a local shop make and machine on a collar?
any competent machine shop will easily be able to put that ring on it, but they'll want money. honestly, just put the pulley on your car and see what happens. replace the front main seal when you install it. If you have problems, then pull it off and send it for repair- just make sure you keep your stock pulley and belts.
I can guarantee you will have problems. I had mine one for less than a year and I saw a wear line in the aluminum develope. I will be sending mine back shortly. I didn't see a leak yet but I know it's coming if I let it be
If the seal is new, don't worry about it. But if a machine shop has to install a new sleeve, expect to pay for at least 1 hour of labor.Now that's about $60. Still want to hire someone to do it vs just sending it back?
id rather go pay that than have to wait for me to send it and get it back...plus id have to pay shipping to asp. Will most machine shops know what im talking about if i say, " hey, can you put a sleeve on my pulley?" and will they know what size it needs to be and everything...(first time hearing about a sleeve on a pulley, but it sounds important) Thanks again for the help
Just send it in. It's only gonna cost you the shipping there which will be like 10 bucks max. It was only 5.30 for me.
I know mizeree x sent his in and the turnaround time was pretty quick he said
Originally Posted by Brad92SE
This thread has me scared!! Where exactly did you see the wear at on the pulley?
is collar/sleeve just for asp pulleys or all pulleys? I happen to come across this and was wondering if a sleeve/collar would be need.
http://store.yahoo.com/streetbeatcustoms/asp339800.html
I'm almost 100% sure that's an ASP pulley. Same price as ASP's site and it looks the same.
look at the part number on that one you linked to.
guys, the problem isn't a bad design or anything, it's just the fact aluminum is a very soft metal. when your engine is turning several thousand RPM and you have something rubbing against a piece of aluminum, it WILL wear. usually it doesn't leak, but in some cases it can.
rbarnes
Dec 31, 2015 06:29 PM
