NOISE when i turn off my car... ????
well, i came home, turn off my car and i walked away from my car and when i was ready to get in my home, i heard some strange noise under my car, i was like wtf, i went close to my car and i think its under my car, near to exhaust but im not sure, anybody has the same experience with me?
Originally Posted by splat
Check your oil level...
you gotta be more specific, but it could be valve lifters ticking, your pipes could be cooling down, or the cat. It's probably normal. depending on the severity.
Im thinking maybe its normal
Yes...usually if you hear a ticking (and it's not normal) it is your oil level...Just park your car on a level surface, pull out the dipstick, start the car for 5 seconds, kill it, put the dipstick back in, check the oil level...if it's low, refill it, and see if the ticking persists.
Originally Posted by superpaul33
mine makes 3 or 4 clicking noise each time i shut it off. I only hear it when it is quiet. other than that i dont know.
There was a tread on this like a year ago on 00-01 models. Its something resetting itself and I can't remember what it is....Icy2kSE I think you know what it is. Its normal, and nothing to worry about. But I'm not sure if its the same noise your discribing on your 02-03
Originally Posted by dennisuello
i've got this whining/buzzing sound for couple minutes after i turn it off.
Greg
Is the sound similar to like a small engine or servo motor. I had the same engine noise for when I would shut my car off too. It was the electrnic motor mount (front one). I spoke to a friend of mine and who works for Nissan and he told me to unplug it. I did so but I need to bring it in to get repaired.
Hope this helps!
Hope this helps!
sounds like a electric motor mount, if your car is a automatic then it will have those electronic engine mounts. Locate the plug and unplug it, see if it makes a difference, you will not get any check engine lights or anything from doing that. In the last few Nissan TechTalk magazine periodical Nissan dealers get, they had a little blurr in there bout the motor mount buzzing problems.
So what did the TechTalk magazine say specifically about the buzzing problems? Is is truely a problem that needs attention or just an annoyance that can be ignored?
here's the TSB about the buzzing from the Motor Mounts... http://maxima.theowensfamily.com/tsb/NTB01-010.pdf
Originally Posted by kloogy
Mine did that too for a long time....doesnt seem like its a big deal...
i've had the same buzzing noise coming from the rear driver's side.
finally raised the rear of the car after coming home from work, and it's definitely coming from a module right next to the rear driver's side wheel. i guess it's a module related to the fuel system or braking system. i have no clue what it is yet, but it's definitely not the motor mounts in my case.
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
ballerchris510
Sep 11, 2015 05:29 PM
