installing foglights
How easy is it to install the headlights (how much time/effort)? Does it make much difference whether to install the factory or aftermarket (RoadBoy)? I have heard that the cars already come pre-wired for it, is it really so (I have a 96 GLE)?
Any additional comments welcome
Roman
Roman
My preference? Factory. All GXEs with C&C, and GLEs come prewired. Call or visit your local Nissan dealer and ask them for the foglight installaion kit, but make sure to tell them that you have a GLE, or else they will give you the SE kit, which is different. The foglights look and operate exactly the same as the SEs. Its turned on by a switch on your turn stalk (that turn signal thingy). Cost: from 200 to 240 depending on where you get them. Alot of people get them from Courtesy Nissan in Texas, they give Maxima.org members a discount on certain things.
Originally posted by WaarrEagle
You can get them for $176 plus shipping from Courtesy online. I ordered mine a few weeks and installed them no problems.
I was wondering if the blanks in the lower bumper are easily removed or if I need to get one that is already cutout. Also, how do i tell if i have the C&C package?
I installed hyper white aftermarket lights and think they look a lot better than the factory. It took over an hour to install. I originally had it wired from the battery to a switch but kept forgetting to turn off the foglights. Now, I've got the wired running from the power wire of the sidemarkers so that the foglights cut off and on when my parking lights do.
differences?
I was just wondering what the differences are between the SE/GLE foglights. When I bought mine half a year back from Courtesy, I never told them and the set they sent fit okay--but I was just curious...so maybe next time I won't make a boo-boo...
Re: differences?
As for the fpglights, no difference. But the GXE/GLE foglight kit COMES with the turn stalk, the relay, the cutout pattern for the bumper, the rubber for the hole in the bumper and the brackets. If you already had the SE, you wouldn't need any of these.
I believe that the GXE's power seat only came with the C&C package. Do you have one? Also, something about intermittent wipers and/or Cruise Control.
They are taped up behind the bumper in the area just below the headlights with a bit of gray tape. Its rather easy to find if you take off the underbody guards (those plastic things that cover the engine on the bottom of the car) and look up. aThose things are in place with three screws.
Two things
1. Fogs are prewired in the GXE only if you have C&C AND ABS and auto tranny.
2. Courtesy has the fogs for $200 (95-96) and $227 (97-99). http://www.nissanparts.cc has the 97+ lights for $171.
Just got my courtesy foglight kit for 95 GLE
Help! They didn't include a instruction for the installation. I have no idea what to do with this good stuff. Does anybody have step by step instructios for the kit(hopefully with pics)?? Also, what is the best "tool" to cut out the hole? Any suggestions on the type of knife(or is there a better tool than this?) that I should use? Please help!!
Roman
Roman
Let me know if you get the factory fogs. I have a 96 GLE also but my front bumper has some funky covering where the fogs would go. It's the shape of the fogs but has some textured lines running across them. Do you have the same getup? I was just wondering what it looks like if you cut the bumper cover and then install fogs. Thanks.
Re: Two things
Re: Just got my courtesy foglight kit for 95 GLE
This is a copy of the factory install manual. I used a straight edge and a heat gun to cut the material, its rather simple if you have a sharp cutter. Watch out for the inside top edge though, its the hard part to cut out smoothly.
Re: Re: Just got my courtesy foglight kit for 95 GLE
http://www.bol.ucla.edu/~cchiu1/fogs.html
The ONLY difference is the cutout. For the early 4th Gens, its a hole that you have to cut out, for the late 4th gens, its the bar thing. Just use a heat gun at a medium setting about 1 foot away from the bumper and cut, it should cut like butter. You should smooth out the hole, but it is covered by a gasket, so it doesn't have to be exact.
Fog Lights on 1996 GLE
I wanted to add fog lights when I bought my GLE but the Nissan dealer advised me against it, saying that the factory GLE wiring would not allow it. I am really interested in this topic and would appreciate any info that proves it can be done.
Roman
Roman
MaxLife17
Jun 27, 2019 01:37 PM
Hdnseek
Sep 9, 2015 05:55 AM
