What do you need to buy to make an oscai?
Old Apr 11, 2001 | 04:33 PM
2001SE's Avatar
Could somebody please tell me what stuff i need to buy to make an oscai. Does anybody know about how much hp does it add?
Old Apr 11, 2001 | 04:40 PM
mdeal's Avatar
Check the first picture here: http://www.fourthrock.com/maxima/oscaiinstall/
I got my stuff from Home Depot. You can use any hose/coupler/etc that you choose. I believe it is punkdork who has good, detailed instructions. It is an easy install.
I'm not sure about the HP increase. If you want to realize the gains, I would highly recommend throwing a K&N filter in ($60).
Good luck.
Old Apr 11, 2001 | 04:45 PM
2001SE's Avatar
Good luck.
How wide is the hose
Old Apr 11, 2001 | 04:48 PM
mdeal's Avatar
The opening on the bottom of the scoop instake is 3". You can purchase any diameter, but it has to taper down to 3", either by hose diameter, getting a fancy coupler, tape, or whatever.
The coupler you see in my pic is a 3" to 3". Home Depot has a variety, such as 4" to 3", 2" to 3", 3" to 3", etc.
Old Apr 11, 2001 | 04:49 PM
mdeal's Avatar
Here is what the bottom of the scoop looks like, where you'll hook up the hose you bought: http://www.fourthrock.com/maxima/osc...l/DSC00031.JPG
Old Apr 11, 2001 | 05:48 PM
2001SE's Avatar
All i need to do is to open up that scoop and connect the hose to it. and then where i put the rest of the hose?
Old Apr 11, 2001 | 06:56 PM
mdeal's Avatar
I let my hose dangle almost straight down to where the plastic stuff is (you'll see what I'm talking about if you look straight down over the scoop). Others have wedged theirs through the plastic or what not. You could direct it towards the front of the car in some form or fashion.
I found it to be tight quarters, so it was hard to direct the hose anywhere but straight down.
Old Apr 11, 2001 | 07:50 PM
2001SE's Avatar
Can't water get in the hose.
Old Apr 11, 2001 | 08:18 PM
mdeal's Avatar
It possibly could, but highly unlikely. That is alot of hose to have to travel through, plus the filter at the end, in order for water to be injested. It should not be a problem. I would not ride through a ditch or 2 foot of water, though.
The only way it could inject water is if the end of the hose is submerged.
I would not have installed it had I thought it would suck up water.
Old Apr 11, 2001 | 09:16 PM
2001SE's Avatar
Thanks for all your help
Old Apr 11, 2001 | 09:49 PM
punkdork's Avatar
Plus with the scoop to still suck in air.. that's the path of least resistance.. shouldn't really have enough power to get water too. You could always get an AEM bypass valve and work it into your setup if your're really concerned.
Old Apr 11, 2001 | 09:56 PM
maximawanabee's Avatar
Do you gain any deep throated sounding growls from the exhaust when you accelerate by installing the OSCAI?
Old Apr 11, 2001 | 10:03 PM
punkdork's Avatar
I don't really know of any intakes that increase exhaust sound.. they increase intake sound... anyway the OSCAI is the quietest intake other than stock. PR CAI is the loudest and the cones are right in the middle.
tgreen
Oct 18, 2015 06:18 PM
97_GXE
Sep 15, 2015 06:47 AM
220k+ A32
Sep 11, 2015 02:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
