Possible VIAS Problem
Old Nov 10, 2004 | 01:36 PM
Maxima-2's Avatar
I know it could be due to a number of things, but I was just reading up on VIAS and was hoping an expert on the issue could guide me a bit! I know it might be coils, plugs and wires, or the MAF. I have a 2000 5 speed with 51k on the clock injen intake y-pipe and high flow cat. When accelerating its been a bit sluggish/hesitant thru lower RPM's and then I get my powah back in higher RPM's. The car is coming off the road this weekend, but in your opinions should I replace coils, MAF and plugs/wires this winter and then check out the VIAS in the spring, or assume it most like is malfunctioning?
Old Nov 10, 2004 | 01:37 PM
Larrio's Avatar
The Definitive AE Master
VIAS is only actuated at high rpms, so you can rule that out for now.
Old Nov 10, 2004 | 04:53 PM
Matt_01SE_20th's Avatar
MAF, in my case, affected 3k-5k rpm. so i would say most likely not that.
Old Nov 10, 2004 | 05:25 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
are the coils the original ones? have you changed the plugs yet? no wires to change, just have the coil in a distributor-less ignition. maf will affect all areas since it helps determine a/f ratios at partial throttle and is solely responsible at wide open. vias you would only feel above 5k rimps unless the cup or rode is broken and the rod is open all the time which would normally only happen after 5200 rpms.
Old Nov 10, 2004 | 08:34 PM
Maxima-2's Avatar
thanks for your responses guys. I am planning on doing coils and plugs over the winter months and MAF in the spring time! I just read a thread and a light went off in my head so I thought I would ask!
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Turbonut
46
Oct 21, 2015 08:28 PM
Dasmith
Sep 23, 2015 08:28 PM
Kalrakam
Sep 16, 2015 12:30 PM
0m3nc0w
Sep 11, 2015 05:21 PM
