Spoiler LeD Light help.. this things junk.
Old Nov 21, 2004 | 06:29 AM
bobjohnson's Avatar
Blazin......
What up org. havent quite been around much... i drive to much now.
Ok my spoiler light doesnt work and hasnt since i painted it.
I cut the wires before i saw that connector which light=wire connects.
So i cut the spoiler light free. then saw the connector and cut that off for some dumb reason.. dont ask.
So when i when to put it back together i lost that connector and hard-wired the 2 wires up. But Nothing. I switched the +/- around n stuff but nothin still.
*I did put the light wires +/- on the battery and still no light. no work. nada.
Q: Was there a resistor in that Connector?
Q: Is the light fried?
Q: Should i use a test light on the lose wires hanging in the trunk to see if it gets power.. if you say yes does a 40 w reg. bulb work orrrr... what does?
Anyways.Thanks for any help in advance. Much App Mwest.
Old Nov 21, 2004 | 08:00 AM
bigleman's Avatar
Advocatus Diaboli
...are you pressing the brake when you are testing? i know its a dumb question but i had to ask... id say use a multimeter to test the wires and see if you are getting voltage, if not you could have blown a fuse somewhere
or your light might be bad...
Old Nov 21, 2004 | 12:37 PM
97WhtSE's Avatar
I had the same problem Check ur fuse. Currently mine is hard wired and it works the connector caught on fire for some reason.
Old Nov 22, 2004 | 12:40 AM
bobjohnson's Avatar
Blazin......
ha... yes im havin someone press on the brake when i test it.
I dont know where the single fuse for that is>..? Wouldnt it make the rear lights not work as well if thats the case or does it have a private fuse..?
thanks for any help.. mwest..
doctorpullit
Apr 5, 2017 12:59 PM
4doorGTR
Sep 11, 2015 04:09 PM
mpbclutch33
Aug 25, 2015 06:23 AM
spidgeon
Aug 18, 2015 05:46 AM
220k+ A32
Aug 17, 2015 03:57 PM
