Alarm remote programming messed up
argh! i bought a new remote for my moms 97 maxima off eBay and it came with directions -
get inside the car, close the door
using lock/unlock button in the car lock the car
insert key into ignition, take out completely
repeat step 3 untill the turn signals on the dash blink
once the signals blink, turn the key to the on position (this is where i messed up)
her car has a replaced ignition from nissan since it was faulty, and i now have 2 sets of keys (door, and ignition) and i used the wrong key (door) to start the procedure... and i unlocked the doors using the switch in the arm rest to get out... fustrated, and went inside and realized i used the wrong key. now i cant get the turn signals to blink. my origional remote doesnt work now and when i put the car into ACC and hit the button, the lights on the dash flash. (oh also, the little switch on the door that triggers the alarm, and the interior lights is broken.... (its not my car and it got broken from a minor accident))
There are more detailed directions in the FAQ's. I bought some the other day too.
http://forums.maxima.org/showthread.php?t=254238&page=2
It'll work, just make sure you have the right key for the ignition this time and you'll be fine.
? You can't open the driver's side door ?
As long as you have...
1. Ignition key
2. Driver door power door lock and manual lock switches work
3. OEM Remote(s)
4. Driver door opens
There's no reason they won't work.
1. Ignition key
3. OEM Remote(s)
Originally Posted by exiva
the door opens, but you know that rubber switch on the bottom of the doorjam that triggers the lights and alarm.... is stuck in the down position
got any info on doing this? well, id rather both switches work.... but i guess for the time being.. so i can get the alarm working again
Done.
unplug? got a picture or something?
You really don't need a picture. Just go take the screw out and pull out the switch. You will see a plug attached to it. Unplug it. Replace with passenger side switch. Program your remotes.
You could try a local junkyard or an org member that might be parting out his car.
Check the classified section of this forum to see if anyone is parting out a Max and see if he'll send them to you with anything else you might need.
I needed two of them about a month ago and an org member was parting out his car and I got the switches along with some other stuff real cheap.
litch
123
Jan 4, 2024 07:01 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
