Wheel Bearing dust/grease cap help
Old Dec 13, 2004 | 06:39 AM
jklinstein's Avatar
This is for a '99 Maxima I bought this fall, and I just put new tires on it. The guy changing the tires pointed out that the "inner hub" is missing on two wheels.
It's the 2-2.5" diameter "cap" that keeps grease in the wheel bearing area and keeps the dust/dirt out of the bearing. It fits over the threaded rod, cotter pin, and nut sticking out of the center of the brake assembly. Could anyone help out with a technical name for this cap so I can find it online (or a recommendation on where to find it)? Are there any other parts I'll need in conjunction with the cap? Also, how urgent is it to get this replaced?
Thanks, I appreciate your help.
Jacob
Old Dec 13, 2004 | 07:01 AM
Bluebird's Avatar
I am Roid Rage
Dust cap
Just go to the dealer, can't be too much $$$.
Old Dec 13, 2004 | 10:35 AM
jklinstein's Avatar
You were right, they're just $8 each at the dealer. I also found out that they only go on the rear axle, so I don't actually need them.
Old Dec 13, 2004 | 10:47 AM
Bluebird's Avatar
I am Roid Rage
Yep, only on the rear.
P.S. If you get rims for your car, you'll probably need to remove the dustcaps to fit the rear wheels on.
bbsitum
Sep 6, 2019 07:31 PM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
