Weird noise from front end
Old Dec 13, 2004 | 12:55 PM
rik3k's Avatar
Hey guys,
Whenever I'm driving (ie. not standing still) my car makes a really weird "banging noise", and it's coming from the front end. It looks to be related to the wheels since it's like a cycle (ie. it appears to be making the noise once every wheel turn, more or less). When Under braking, the noise is louder, and when accelerating, the noise stops or is barely noticable. And so I belive it's a moving part which is sticking to the wheel, brakes, axle (or whatever) under braking, and seperating when accelerating. It does this ALL the time. I can't get under the car (too much snow everywhre, and no garage). I want to bring it to a shop but was wondering if any of you every had this?
By the way, I had my CV boots replaced not too long ago (didn't rebuild the axles). Could this be CV relate? Thanks guys.
Old Dec 13, 2004 | 01:00 PM
DJMaxGLE's Avatar
Maybe a pad is rusted to the rotor? I got a banging/thumping sound when I hit the brakes that started out fast and slowed down as I came to a stop. If that's the case, you can resurface or replace the rotor.
Old Dec 13, 2004 | 01:26 PM
rik3k's Avatar
Brakes got changes 2 months ago, doesn't seem to be brake related.
Old Dec 13, 2004 | 01:37 PM
vipervadim's Avatar
I like Maximas
check the undercar shields those have been rattling and causing noise on my car, or a sticking brake caliper can also attribute to the noise.
see if you can hear which side it's coming from
Old Dec 13, 2004 | 01:39 PM
rik3k's Avatar
But could it be a CV? I don't hear a clicking sound when turning but when going straight I hear it.
Old Dec 13, 2004 | 02:18 PM
NetFurie's Avatar
I had this sound when the tire place forgot to put my lug nuts on. They had one finger tight and the rest sitting on the floor in their shop.
If I was accelerating, the sound was almost non-existent as there was enough tension to keep the wheel from banging. I'd only hear it if coasting or braking.
Granted, I didn't spend a lot of time testing... just long enough to get a mile from the shop, realize things were terribly wrong, and drive back.
Old Dec 13, 2004 | 02:31 PM
zachosz's Avatar
In my case it was the shop forgot to put the bottom bolt on the caliper, so everytime i braked the caliper would move back and hit my wheel. Make sure your caliper bolts are tight! When you brake does the brake pedal vibrate? If so it could also be your rotors, you should get them resurfaced.
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
JoshG
21
Sep 4, 2015 09:04 PM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
