Car ideling at like 550???
Old Dec 15, 2004 | 12:56 PM
97maxxx's Avatar
sorry such a stupid thread but please bear with me-after the car warms up for a few minutes it then idles at around 550-600 it runs so smooth but seems a lil low. how can i increase it to like 700 or so. Isnt the normal idle around 700? let me kno thanks
Old Dec 15, 2004 | 01:08 PM
Loe max's Avatar
http://home.earthlink.net/~maxfaq/
Click on 'Maintenance' off to the left, then select '4th gen idle speed' in the right field and it will give you directions to adjust your idle speed.
Old Dec 15, 2004 | 01:13 PM
Vyrus's Avatar
My car also idles that low once warmed up, but I've never had any problems with it so I see no need to adjust it.
-Cyrus
Old Dec 15, 2004 | 01:17 PM
97maxxx's Avatar
thanks a lot -will do it 2m -but j/w what is everyone elses ideling at? is 550 normal for a warmed up car?
Old Dec 15, 2004 | 01:22 PM
Akumachan's Avatar
I never narc'd on nobody.
im at about 600-650
Old Dec 15, 2004 | 01:27 PM
Terran's Avatar
According to my haynes...
1995
stick->550-650
auto->600-700
1996 and later
stick->525-625
auto->600-700
Old Dec 15, 2004 | 04:44 PM
Ant96GLE's Avatar
Yea thats pretty normal.. I idle at about 550 to 600 all the time...
Old Dec 15, 2004 | 06:03 PM
Bonka's Avatar
Schnell kaputt
Auto.
I idle that low also. No shakes.
Old Dec 15, 2004 | 07:57 PM
konak85's Avatar
Hey try doing the throttle body cleaning as explained at http://www.motorvate.ca/mvp.php.
It helped my rough idling.
Old Dec 15, 2004 | 08:12 PM
konak85's Avatar
Are you talking about idling in drive or in park?
Old Dec 15, 2004 | 08:21 PM
97maxxx's Avatar
drive and yea i did clean my tb-the car isnt rough ideling i just thought is is low -well it seems a lil rough but it is also 20 degrees outside so that can be it also
Old Dec 15, 2004 | 09:08 PM
ChiShiFu's Avatar
hey, guys, first post here... don't know if it was answered before but search isn't working for me.. so a quick question...
when i start my car, the initial ignition revs it over 1000, but then it drops quickly and stalls. The only way i can get it to idle is the rev it a little bit, very lightly, nothing over 1500 w/the throttle for a few seconds, then it idles around 1000 for a little till it warms up and falls to around 600. It only stalls when i start it up in the morning to go to school, or if it's been stationary for 5 or more hours. Do you guys think it's throttle body also?
ChiShi
*edit, 96 GXE auto
I looked at the TSB, but was wonering if there was anything DIY fix and see if it worked. Like the TSB says, my car has difficulty starting after some ours of cooling or overnight at cold temps. It says it's running overrich fuel during cranking so i gotta keep the cranking period extended to get it started. Is there anyway i can verify/fix this?
Old Dec 16, 2004 | 03:31 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you should never need to adjust the idle speed. if your idle speed is incorrect, look else where to solve your problem. adjusting the idle speed is just a quick fix.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
