car jacking questions
whats the easiest was to get to the alarm system wires after breaking into the window? hhmm... alright my real question is, can you jack the back half of the car using the beam that goes across from the left tire to right? also, you can jack the car from the sides anywhere along the frame that's right under the doors parallel to the ground right? my friend told me that and said that there is no exact spot you need to put it, is he right? thanks
I've lifted the rear from the beam... No apparent ill effects so far...
As for the sides... ONLY AT THE DESIGNATED AREAS! between the two notches... or you'll bend part of the rail like I did... It looks bad afterwards...
Garage jack points
... can you jack the back half of the car using the beam that goes across from the left tire to right? also, you can jack the car from the sides anywhere along the frame that's right under the doors parallel to the ground right? my friend told me that and said that there is no exact spot you need to put it, is he right? thanks
(1) The leading end of the fore-and-aft stamped steel brace which is under the engine/transaxle in the center of the vehicle. Jacking at this point raises the entire front of the vehicle.
(2) The center point of the rear axle. Jacking at this point raises the entire rear of the vehicle.
I replaced the original cup-like steel saddle on my floor jack with a rubber-faced flat plate (Harbor Freight #36004, $10 +s/h, or equivalent.) This is kinder to the car, marks it up less. Another approach would be to fashion a rubber insert for your cup-like saddle. Collect one of those truck tire treads which litter the highway roadside. Look for a thick one. Cut out a piece which will fit inside the saddle. Let it "float" or secure it with a big gob of adhesive, as you wish.
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
