2001 GLE lacking power at 66k??? suggestions
Old Dec 21, 2004 | 04:07 PM
tjfroo's Avatar
My 2001 GLE has only 66k on it and has always been maintained properly. The check engine light has not been on in about a year since i needed an O2 sensor. Recently it seems to lack power taking off when i get on the on ramp of a highway. It used to kick up to over 5,000 rpm and just go, now it hits about 4,000 and is quick but not he same. No lights are on though?? What could this be??
Old Dec 21, 2004 | 04:09 PM
upstatemax's Avatar
do a tune up, crappy plugs caused my reduced power. put he new ones in and right away a noticable diff.
Old Dec 21, 2004 | 04:18 PM
tjfroo's Avatar
so it's probably not the timing belt or coils then? that's what i'm most concerned about.
Old Dec 21, 2004 | 04:59 PM
upstatemax's Avatar
does not really sound like coils. when they go you usually have a problem starting the car, hesitation when you hit the gas (nothing happens), and rough running.
Old Dec 21, 2004 | 05:51 PM
SoonerFan's Avatar
Cletus
i would do a tune-up and see if that helps.
replace sparkplugs
replace filter (if stock)
clean filter (if intake)
chain oil
clean throttle body
use BG44K for injectors
use seafoam for intake manifold
Old Dec 21, 2004 | 05:54 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Get a new MAF sensor along with all the stuff Soonerfan mentioned. BK44K can be bought at alot of local car dealers, do a search online for any local dealers who use this stuff. My luck the near by Dodge dealer uses BG44K.
Old Dec 21, 2004 | 05:58 PM
SoonerFan's Avatar
Cletus
i recommended he do those things before he dropped money on a MAF
Old Dec 23, 2004 | 09:25 PM
super maxi-pad's Avatar
does this bg44k go in gas tank?
Old Dec 24, 2004 | 12:22 PM
yes fill up the car and dump the can in the tank
Old Dec 24, 2004 | 02:17 PM
Kevlo911's Avatar
Kevlo for President
Fix the manifold, it is probaly broken. Spirilis(spell?) has hte link in his sig.
lowpost99
Oct 26, 2025 06:53 PM
gustavison
Oct 4, 2015 06:50 PM
QueensMAX
Sep 15, 2015 04:14 AM
spidgeon
Sep 9, 2015 03:36 PM
mikebla
Sep 3, 2015 05:37 PM
