how do you know your coils are bad?
Old Jan 18, 2005 | 06:14 AM
1HOTMAX's Avatar
help help
how do you test if one of your coils are bad instead of changing all 6?
they cost a lot of pesos each piece. obd scan said cyl 4,5,6 are missfiring and car running too lean!
i tried changing sparkplugs,dry gas, cevron fuel injector cleaner but no luck. check engine light still comes on!
thanks
Old Jan 18, 2005 | 06:32 AM
schmatt's Avatar
Disconnect the coil. Check the resistance between the center pin and the pin to the right of it. This would be if you have the tab used to lock the connectors pointing up. The resistance should be greater than 0 Ohms. If it is 0 Ohms, then it is bad. This procedure is directly from the FSM. If you want to fix this yourself, then you should take a look at the FSM and follow the procedure in there to determine what the actual problem is. There are a lot of other things it could be. It could be an O2 sensor or the ecu or the fuel pump or a bunch of other things. People just tend to blame the coils because of the known problems with them.
Old Jan 18, 2005 | 03:28 PM
1HOTMAX's Avatar
how do i determine if it's an o2 sensor?
Old Jan 18, 2005 | 03:43 PM
Ant96GLE's Avatar
RUn it on a scanner, it will tell you the voltage for each 02 sensor independantly...
Old Jan 18, 2005 | 04:31 PM
ny96max's Avatar
why does it matter Thai? you never drive your max anyways!
Ant
Old Jan 18, 2005 | 05:14 PM
TsingTsaoNYC's Avatar
Even if you did, you would never know the difference with all that bling on your car!
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
