Always something...
Always something...
with these cars, ain't it. Still better than a car payment, though.
Anyways, 88 Maxima starts, idles, and runs pretty good, hot or cold, but when it shifts into overdrive and I accelerate, the front end will shake violently until I let off the gas. I can then accelerate a little more slowly and it will speed up OK.
It doesn't do this in any other gear. It really only happens at low RPM (just after shift) in overdrive.
Anyone have this happen yet?
Where are the rpm's in overdrive when you do this? I wonder if something is up with your overdrive. Does car feel like it's kicking in and out of overdrive. Have you check your ATF fluid lately?
S
S
S
S
Fluid level is good, btw...
Was it directly after you put a TPS in...or developed soon after? What happens if you just leave the car out of overdrive? What happens if you let off when it shifts into overdrive, and then gas it again?
Here are the thoughts I have so far. Torque convertor lockup is having a problem. Either it's not locking completely during an accelerated shift, or is just not locking at all.
S
S
mine does the same thing I just figured the torque converter lock was not working right hell it still drives good just an annoying shake from time to time.
but hell if anyone knows what the problem is and a way to fix it that would be great.I hate auto trannys
S
S
Hadn't tried running it without OD button engaged.
I will do so today.If I let off before it starts to shake (in OD), I can ease back into the gas and it will slowly get up to speed and stay at speed, 50 to 70 mph (don't have any problem until it gets to about 50 mph and above). A big hill might make it shake a bit if I try to speed up too fast.
Problem with that is he can let off and gradually accelerate and it'd be fine. If it was axles....it would always do it when your accelerating in even gradually. So I don't think it would neccessarily be axles.
S
S
Ma><iManiac
Jan 20, 2003 11:54 PM
