Clean Throttle Body!
Old Feb 21, 2005 | 10:29 AM
whtslprmax's Avatar
Engine is way more responsive now. Just used B-12 Chemtool from Wal-Mart. Less hesitation for sure. Very inexpensive task (took less than an hour) that works wonders.
Old Feb 21, 2005 | 10:44 AM
MaxOctane's Avatar
What was your exact procedure? Did you remove the battery terminal before you started cleaning?
Old Feb 21, 2005 | 12:17 PM
whtslprmax's Avatar
Disconnected Negative Terminal...sprayed...scrubbed with toothbrush and clean towel...too include the butterfly. Continued until the towel was clean after wiping the inside. I did the same thing 20K ago. Simple and works good. Just reconnect and let the car idle. It will run sh!tty for a few seconds until it burns off the chemicals you sprayed inside. Purrs like a kitten now.
Old Feb 21, 2005 | 12:37 PM
ZeRo MaX's Avatar
are we "SUPPOSE" to just disconnect the negative terminal?
Old Feb 21, 2005 | 02:16 PM
whtslprmax's Avatar
Yeah. Why not? I did simply because I had to remove the intake. That way the computer refreshes and recognizes everything. Overkill? Maybe...but I've never had any problems.
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
