Please Help, I'm Sad
Old Mar 1, 2005 | 01:00 PM
Brendan's Avatar
Hey guys, my 92 se has been running funny lately. It's the ve engine, i am experienceing power loss through the gears, it just doesn't feel as quck and responsive as it used to, and when im idle my rpm's will jump up and down between about 800 and 2500 , up and down, and there have been a few times its wanted to stall out when i come to a stop. I know this is probably a simple question but whats the most likely problem im encountering here? sensor? injector? THanks guys.....
Old Mar 1, 2005 | 01:09 PM
internetautomar's Avatar
mod or sell?
first check to see that all 6 cylinders are working
Old Mar 1, 2005 | 01:30 PM
Brendan's Avatar
best way to do that?
Old Mar 1, 2005 | 01:45 PM
mod or sell?
disconnect the coils one at a time with the car running, and make sure that each one causes the car to run WORSE.
if one doesn't cause a change then you have a starting point on which cylinder is having a problem.
Old Mar 1, 2005 | 02:41 PM
Brendan's Avatar
ok so when i disconnect the middle front one the engine sounds the same so i belive that one isn't firing, what do i do from here?
Old Mar 1, 2005 | 02:48 PM
mod or sell?
swap the coils between that cylider and the one next to it. if the miss moved to the other cylinder than it's a coil.
if not pull the plug to make sure it's good.
also check the resistance on the injector, it should be 10-14 ohms.
Marc2theMax
Sep 28, 2015 08:13 AM
wingnut2006
Sep 19, 2015 06:13 AM
raffivegas
Aug 23, 2015 09:54 PM
speedracer3
Jul 10, 2001 01:08 PM
