Please Help, I'm Sad
Old 03-01-2005, 01:00 PM
Brendan's Avatar
Hey guys, my 92 se has been running funny lately. It's the ve engine, i am experienceing power loss through the gears, it just doesn't feel as quck and responsive as it used to, and when im idle my rpm's will jump up and down between about 800 and 2500 , up and down, and there have been a few times its wanted to stall out when i come to a stop. I know this is probably a simple question but whats the most likely problem im encountering here? sensor? injector? THanks guys.....
Brendan is offline
Old 03-01-2005, 01:09 PM
mod or sell?
internetautomar's Avatar
first check to see that all 6 cylinders are working
internetautomar is offline
Old 03-01-2005, 01:30 PM
Brendan's Avatar
best way to do that?
Brendan is offline
Old 03-01-2005, 01:45 PM
mod or sell?
disconnect the coils one at a time with the car running, and make sure that each one causes the car to run WORSE.
if one doesn't cause a change then you have a starting point on which cylinder is having a problem.
Old 03-01-2005, 02:41 PM
Brendan's Avatar
ok so when i disconnect the middle front one the engine sounds the same so i belive that one isn't firing, what do i do from here?
Brendan is offline
Old 03-01-2005, 02:48 PM
mod or sell?
swap the coils between that cylider and the one next to it. if the miss moved to the other cylinder than it's a coil.
if not pull the plug to make sure it's good.
also check the resistance on the injector, it should be 10-14 ohms.
Marc2theMax
09-28-2015 08:13 AM
wingnut2006
09-19-2015 06:13 AM
raffivegas
08-23-2015 09:54 PM
speedracer3
07-10-2001 01:08 PM
Quick Reply: Please Help, I'm Sad
