how to on hardwiring a radar dector?
Old Mar 6, 2005 | 08:18 PM
tbombs32's Avatar
the how to hardwire a radar detector link in the stickies is broken is there any other how to one this or can anyone help me out
thanks
Old Mar 6, 2005 | 08:32 PM
maximum810's Avatar
I have my V1 hardwired into the reading lights of my 99' max. If you want to hardwire it there, it's pretty much self explanatory...just run the clip to the light power source, and use one the the screws up on the rear-view mirror for ground (if I can remember correctly). The most you need to take apart is the rear-view mirror...and that reading light panel. The only problem I had was trying to get the kit to fit in between the headliner and the winshield. It's kind of tight, but not bad....just gotta pull on it some.
Old Mar 7, 2005 | 08:23 AM
MrEous's Avatar
^ Jeff™
We ran the hardwire between the windsheild and headliner, down the inside of the pillar and then through the dash to the radio power/negative. Soldered the connections and it all worked great.
We were going to try the map light power but I had heard there might be an issue with power...so better safe than sorry I suppose.
- maximum810...Comin to the DNE meet on Saturday??? lol
Old Mar 7, 2005 | 08:53 AM
Mr.Duck's Avatar
on the runnning it through the pillar, and dash, but i spliced it into my cig lighter
Old Mar 7, 2005 | 10:21 AM
SPiG's Avatar
SomePsychoGuy
I have run it through the A pillar on several cars. It is pretty easy. If you look under the steering wheel there is a white/blue wire I think. It is a good wire to splice into if you don't want to use the cig lighter.
for a 5th gen but same concept http://www.freestyleconcepts.com/v1.html
Old Mar 7, 2005 | 10:57 AM
maximum810's Avatar
The only drawback about running the hardwire to the reading lights is that the radar detector will stay on after the car is off....no biggie...manual shutoff.
Since the road-course day is also on Saturday on the opposite end of DFW...it'll be tough to say if I can show up, but I'd like to...not that it's too far...just my car will be beaten up some. Since a few of you are going to ATS to dyno that day....why don't you stop by TMS and check out the course???
Old Mar 7, 2005 | 11:01 AM
MaxKlinger's Avatar
I've been meaning to do this for a while and haven't had the time yet.
Where are you guys mounting your detectors? I have mine mounted relatively low on the dash and I was going to run mine out the defroster vent from the cigarette lighter power wires.
Old Mar 7, 2005 | 11:02 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
dave, you did that yourself? im proud of you.
I run all my wires through the a pillar.
http://forums.maxima.org/showthread.php?t=385193
pic # 2
Old Mar 7, 2005 | 11:58 AM
jackiss2888's Avatar
why does everyone want to hardwire them? what happens when you switch cars?
Old Mar 7, 2005 | 12:12 PM
slimer's Avatar
you unhardwire them
Old Mar 7, 2005 | 12:43 PM
MrEous's Avatar
^ Jeff™
Now there's a thought...I wonder how long of a kitchen pass I can get.
Mine is mounted right next to the rearview mirror...windshield tint strip hides it somewhat. No way I'd leave my v1 down by the defroster vents for everyone to see here in Dallas.
...Umm, my hardwire is an old telephone cord I used...I think it's a couple of bucks brand new so I don't have any worries about that.
Old Mar 7, 2005 | 01:02 PM
oh, so your not using the power cord it came with then... i see...
Old Mar 7, 2005 | 02:34 PM
Entropy's Avatar
Mine is in the middle of my windsheild down closer to the dash. I ran it into the left vent in the middle of the dash and just down behind the stereo and to the back of the cig lighter.
Old Mar 7, 2005 | 02:48 PM
Mr.Duck's Avatar
pic # 2
haha yes steve, alllll by my self i also fixed my system(ground got messed up) all on the same day as doing my oilchange, i was kind of a last minute thing
it is fairly easy to do, took me about 15 minutes, would have taken me 5 if i actually took out my radio i just left it in, and worked under it, scratched my arm up like a bish doing it haha
Old Mar 7, 2005 | 10:07 PM
tbombs32's Avatar
the reason i'm hardwire it is because my cigartte lighter isnt deep enough for the plug on my radar for some reason...anyone else have this problem
Old Mar 7, 2005 | 10:08 PM
Mr.Duck's Avatar
i had this problem, i went a few months with it partially instill worked, was just weird
Old Mar 8, 2005 | 04:48 AM
euromaxima's Avatar
I ran my wires down the pillar, grounded on a screw under the dash and ran a wire to my fuse box, pulled out a fuse that is used when the can is turned on and pushed the wire in where the fuse was and put the fuse back in. Same thing is done to my truck so when i Switch back and fourth I just bring the radar detecter with me.
JRod28
Feb 4, 2016 11:07 AM
Y2KevSE
72
Aug 4, 2008 08:21 PM
_DRU_
Apr 9, 2001 08:14 AM
blackY2Kmax
Jan 3, 2001 02:39 PM
Nick Robinson
Dec 28, 2000 08:19 AM
