Squeak Squeak.. stfu!
Old Mar 9, 2005 | 03:57 PM
fadeaway's Avatar
Go Hokies!!
Christ, my car is squeaking uncontrollably. It has been doing this ever since about 6 months or so ago. I thought it was the springs, or something to do with the suspension (still could be the case?), but I switched to s-tech's and the problem is still occuring. Most of the time I crank my stereo and let my rockfords negate the squealing, but I want to face up to the problem and fix this.
Let me describe the squeak. It's a very noise; only happens at low speeds I Believe, and high pitched. Sounds kinda like a see-saw.. "eee arrr". The noise is embarrasing, and it's really starting to get to me.
I did a little research and saw that it may be coming from the brake system. If anyone has any info. which could be helpful to me please let me know.
Old Mar 9, 2005 | 04:09 PM
Stuntin' 101's Avatar
could be control arm bushings too..
Conrad283's Avatar
I need a truck
If it's the brakes then the rotors may need to be resurfaced because they're warped or maybe you need new pads.
Old Mar 9, 2005 | 04:13 PM
maxgtr2000's Avatar
KH3 by popular demand
when was the last time you changed the brakes? Could be the wear sensors beginning to rear their ugly heads.
Old Mar 9, 2005 | 05:54 PM
a_prince1's Avatar
Does the squeek go away when the road is wet?
Then it is your spring or the control arm bushing.
There is a write-up in the faq's for suspension noise.
Old Mar 9, 2005 | 06:22 PM
Ant96GLE's Avatar
Old Mar 9, 2005 | 06:31 PM
MaDMvD's Avatar
Originally Posted by Ant96GLE
Hahahaha, you're quite the
mrnock's Avatar
Old Mar 9, 2005 | 07:26 PM
fadeaway's Avatar
Go Hokies!!
Sorry I'm just a newbie at mechanical aspects of our cars.. but the arm bushings are in the fronts only right? I'm positive this noise is coming from the rear. I haven't gone through extensive testing, but it seems like it is only the passenger side rear wheel area. I don't believe the noise goes away when it rains, but I'll keep a watch out when it rains next.
But nobody else has had this same "eee arr" squeaking?
The brakes or the brake pads? Don't think the actual brakes have been changed anytime.. I do have 145k miles.
Old Mar 9, 2005 | 08:21 PM
96nismomaxi's Avatar
.org window licker
it could be your strut tower bushings
they sit at the top of your struts and mine just went out and had to change them out not too hard just drop the assembly and youre there all i have to say is hope that u have air tools
Old Mar 10, 2005 | 02:02 AM
dayglo's Avatar
i have some kind of problem like this too...when im goin realy slow almost to a stop i get a loud drum sound like a moan, hollow and loud. i think something bent when i had the ebrake on and reversed like an idiot and rocked the car pretty good. could that bend stuff and cause this?
also i looked at the TSB's and found that it could be a bad brake cable?
Old Mar 10, 2005 | 03:37 AM
Chickan's Avatar
By "actual brakes" do you mean rotors?
If you think it's one of your brakes, jack up the car and spin the tire by hand, see if you can see anything rubbing. While you are there, inspect both brake pads on that wheel too.
Old Mar 10, 2005 | 03:54 AM
Maximathug's Avatar
Key areas to inspect all your mounts, bushings to include the trailing arm(rear only) it connects to the rear beam, and the axle/ wheel hub. And it wouldn't hurt to check if any of your struts are busted. Good Luck.
Old Mar 12, 2005 | 01:50 PM
fadeaway's Avatar
Go Hokies!!
I thought a little.. could this noise possibly be the result of a missing gasket on the strut assembly? Anyone know if not having that red gasket thing (which I think goes towards the top of the assembly) could be causing this noise?
Thanks!
Dan
litch
123
Jan 4, 2024 07:01 PM
SusieQQ
Sep 9, 2015 12:14 PM
MikesChevelle
Aug 7, 2015 05:57 PM
speednsound007
Apr 5, 2001 09:44 PM
Eric L.
Jan 1, 2001 01:54 AM
