Help!!!!! car wont go into gear
i was just now driving my car and it started to get really hard to put into gear... then it became harder and harder, then it took about 10-15 seconds to put it into gear then i just drove home in 2nd gear.... then i parked the car and checked the engine bay.... it seems that there may be some kind of fluid on top of my tranny.... anyone have any idea of what this could be???? I dont just think im low on fluid...
thanks
-JOn
PS---- the car is in my driveway right now and idk what to do....
thanks
-JOn
yeah its clutch fluid, check if that black hose is leaking. also check the container in the driver side corner towards the firewall is empty or not. if its empty you have a leak in the clutch fluid. clutch fluid=dot 3 or 4 brake fluid.
www.motorvate.ca check on the slave cylinder hose replacement and the leak problem
well would it be necessary to change out the slave cylinder? also in another problem, ive had trouble with my clutch grabbing in 1st gear and from 1st-2nd... im not sure what is causing this but im using an act clutch and its really not grabbing at all when im in WOT in 1st gear!?
-JOn
-JOn
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
