For guys running SPRINTS?
Old Apr 6, 2005 | 10:05 PM
sniper615's Avatar
i have sprint springs myself and for those of you who are running sprints, i have a quick question. have any of you cut coils off the rear. if yes, how's the ride, it is bouncy..and unsafe or is it good. if possible post pics. and also if yes where do you cut the springs. the reason i'm asking is the fact that my sprint drop to me looks uneven. i'm runing them with 18's and it looks uneven very noticably.
Old Apr 7, 2005 | 06:27 AM
sean05's Avatar
yea i notice that without cutting the rear it looks uneven, (unless u have a huge sub in the trunk) I cut mine 1 coil in the rear, it sits pretty much perfect. here r a few pictures:
those r a few.. check out the thread for a lot more pictures...
http://forums.maxima.org/showthread.php?t=378781
The ride isnt rough at all. During the winter the sprints with agxs were a fairly rough ride. Now that it has warmed up a good bit i dont mind the ride at all. People sleep in the back of my car all the time and have no compliants about the ride at all. I couldnt tell a chnage in the ride at all after i choped 1 coil off the rear. I dont regret doing it at all. The finger gap in the rear is exactly 2 of my fingers. Front in 1 1/2.
Good luck!
Old Apr 7, 2005 | 06:32 AM
sean05's Avatar
sorry foget to answer your question about cutting them. You have to cut off a dead spring. All this mean is when they are fully compress the spring touchs another spring. I just read this is a recient post. I just cut 1 coil off the top with a hacksaw. If you have a dremel or any other power tool i would use it. if u have any other questions free free to ask!
Old Apr 7, 2005 | 08:59 AM
1FSTMAX's Avatar
dont do it.. cutting them takes away precious suspension travel..
Old Apr 7, 2005 | 09:05 AM
PhillyDonut's Avatar
I'm also running on SPRINTS w/ AGXs and can vouch for everything sean05 said with two solely personal opinions. Cutting the rear makes the ride a little bit softer (better weight balance between front and rear, confirmed by friends) and I feel the car handle turns better BEFORE the coil was cut. Nonetheless, I highly recommend getting the 1 coil cut off the rear but no more than 1 coil b/c any more than that the spring will NOT sit onto the shocks when not compressed (means it can more around if there's no weight compressing it, which is dangerous should you hit a nice bump or jack up your car and it can move off its perch). I had mine cut by a friend's auto garage and I would guess most can do for a few bucks b/c it shouldn't cost much to do assuming if you bring the springs to the shop.
How are the roads in Queens? I've been through Brooklyn (HORRIABLE roads for this setup) a few times and if Queens is anything like Brooklyn then I don't know why you are running with Sprints and on 18"!?!?. I'm on 15" with a lot of rubber!! But if Queens is like Manhattan, then you are OK if you can bear the bumps.
Good luck.
Old Apr 7, 2005 | 09:33 AM
MaximaSE96's Avatar
Maxima Owner
dont cut..u will regret it as much as buying sprints
Old Apr 7, 2005 | 09:49 AM
Can you extrapolate a little why not cut the coil? What shocks did you use them with?
The decision on actually buying it is another story... Riding on Sprints really depend on your tolerance on how the car rides.
Old Apr 7, 2005 | 10:09 AM
1FSTMAX's Avatar
sprints are just pretty much just to slam the car.. You can really race on these springs because there vitually no suspension travel. Even when coupled with AGX, Illuminas, or Koni, the suspension travel isnt there. Also these springs tend to sag over time.
Old Apr 7, 2005 | 10:26 AM
2 Da Max's Avatar
wow come drive a sprint drop over here in ny
Old Apr 8, 2005 | 05:04 AM
sniper615's Avatar
i do that every day and i still feel my car still isn't low enough. my friends have the s tech and his look awesome, but i got a excellent deal on the sprints so i jumped on them. before i was running eibachs which was verryyyyyyyyyy stiff.
but keep the reply comming guys. i'm still strongly considering cutting the rear springs.
Old Apr 8, 2005 | 07:43 AM
lex4style's Avatar
yea sprints are more of a look. I have them and before i thought i made a huge mistake buying them. But over time i have learned to like them. I cut one rear coil on mine and it feels the same.
sagamax's Avatar
Give me a Bud Light Holmes
no cut springs just heavy system
Old Apr 8, 2005 | 03:11 PM
sniper615's Avatar
i put my box back in today and it still looks high
Old Apr 8, 2005 | 03:22 PM
sagamax's Avatar
my system weight about 150lbs i have 2 30lb subs and a custom fiberglass box its really heavy
Old Apr 8, 2005 | 03:26 PM
sniper615's Avatar
lol, i guess that's y u'r drop looks even
Old Apr 27, 2005 | 01:25 PM
sniper615's Avatar
can anoyone recommend a shop in queens, ny that can do this for me
Old Apr 27, 2005 | 03:26 PM
|Bijan|'s Avatar
UCF Lexus
I cut the rear 2 coils....rode fine.
Old Apr 27, 2005 | 04:58 PM
Flava_24/7's Avatar
Boosted Panda
Ive had my Sprints for over 3 yrs, and they do not sag. Ive never even heard of anyone having theirs sag.
Old Apr 27, 2005 | 05:30 PM
nismology's Avatar
Classic uninformed post. Don't pay attention to it. Like water off a duck...
Old Apr 27, 2005 | 07:09 PM
RA030726's Avatar
I'm nutty for Nissans
right considering al has them in one of his maximas and hes tucking tire........ nah they dont sag at all.
Old Apr 27, 2005 | 07:17 PM
Flava_24/7's Avatar
Boosted Panda
Hes low in front, i agree. But thats the only set of Sprints Ive seen go that low. Were they that low from day one, or did they just gradualy get there?
Seriuosly, lots of org members have Sprints. Back in the day, Sprints with KYB's was the most common setup. I havent seen or heard of anyone sagging with them. Like I said, I had mine on for over 3yrs, my buudy put his on a couple of months before me and hes auto. His still look the same as when he first put his on.
LilVito
Oct 25, 2019 08:12 AM
vybz05
Dec 10, 2015 07:38 PM
max1029
Aug 26, 2015 09:51 AM
4 door GT-R
Aug 22, 2015 07:50 AM
maxipower
Aug 21, 2015 11:10 AM
