Flaps underneth the front bumper
So i was changing my oil this weekend and i was looking for the filter. I unscrewed the 2 flaps directly under the bumper and most of the screws are rusted so they broke. Yeah i know i should have checked the forums first since its not even located over the flaps. So now the flaps are loose and anytime the wind picks up i hear a clapping noise. Do i need these flaps or can i just take them off ?
The splash gaurds in both my dad's and my max are removed. The ones that go over the tires are still there but not the ones that are right behind the front bumper. I haven't noticed any negative effects to this. Sometimes if I hit a big puddle, I will get steam from under the hood from water getting in there, but its no big deal. My bolts were all rusted too and were breaking off, so I took out the splash gaurds. I haven't had any problem with water getting on the pulleys or causing any damage in the engine bay, so I'd say go ahead and pull them off.
i need to pick up a new one...mine is bent out of shape from the previous owner, looks like it was bent somehow the wrong way so it hangs down and looks ugly.
i'd keep them on there to prevent water and junk from going up excessively. my friends car stalls out everytime there are decent puddles in the road and i bet it wouldn't if he had these on his car.
Originally Posted by renatonetmail
While taking one of the screws off from the driver side the one that also holds the wheel well one, the screw broke and half of it stayed inside.
how do i get that out?
undercar flaps
if any of you want to get rid of your flaps...I need them...email me at
salehts@yahoo.com
salehts@yahoo.com
Originally Posted by ti2tmax
Screw remover, or drill it and tap a new hole.
edit: drilling and tapping won't work on those will it...
i don't know if there is a screw remover so think... this srew is a philliphs-10mm head and it holds both the end of wheel well flap and a foglight flad together to the car....
yes thats the flap im talking about they atually sell a kit that drills ahole into the screw then u unscrew it and it takes the nail it worked for a concrete nail i think it can take off a 10 mm nut but ya those tend to get rusted the most
very fast because they are located udner the car
to answer your question yes you do need them especially if you have an intake but if not you still do there alot of wires very close and the oil filter is right there not something you wanan risk especially on the NewYork streets
peek a boo:
http://www.mytoolstore.com/hanson/hanson.html
http://www.toolprice.com/category/screwextractors/
"These bits have a 135 degree split point which makes it a self starting drill bit.....blah blah blah"
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
