car is missing
Old May 4, 2005 | 03:15 PM
95stillenmax's Avatar
car is misfiring
ok I noticed that if you ease in it to redline it dosent miss but at wide open throtle it misses horibly I am thinking that is it one of my coils what do you guys think BTW:the car has a rather new set of spark plugs and 210k
thanks Brandon
Old May 4, 2005 | 03:21 PM
DragonMaxima's Avatar
Your title of your message is very mis-leading.
Sounds like your car was stolen.
Chief Brody's Avatar
Do you have any codes?
Old May 4, 2005 | 03:30 PM
Mr.Duck's Avatar
yea i thought your car was stolen too! liar! well atleast it isnt... haha
coilpacks?
Old May 4, 2005 | 06:45 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
car is Missing wheels? Or hood? or the engine is gone?
I don't understand what you are trying to say?
Old May 4, 2005 | 06:51 PM
njmaxseltd's Avatar
Misfiring under a load is definately your coils.
Old Jan 27, 2008 | 05:45 PM
bryont's Avatar
misfiring during accel
Hello, New to this forum and sorry for asking for info already. I have a 96 Maxima (VG??) which will misfire during moderate to heavy accel. Otherwise the engine runs fine and smooth. I see a reply on this thread talking about a possible bad coil. Is there anyway to try and isolate between the 6 or is this a trial and error thing. Info below on problem.
-1996 Maxima auto, 180k miles
-Codes revealed bad knock sensor. Replaced sensor, cleared codes,
codes remain clear at this time 0505. Missfiring still exists.
-Took a look at the TPS with an analog meter. Needle sweep seemed
smooth with no jumping during throttle range of movement. WOT and idle
readings were normal.
-Engine runs smooth at light throttle applications and cruise. Highway
mileage is 27-29. Considered normal.
-Plug are Bosh platnium's with about 40k on them. Inspected, all looked
good.
Any help would be greatly appreciated. Honestly I bought this car for a work car 2 years ago for next to nothing. I have grown to really like this car and plan to find a low mileage SE 5spd once the better half gets out of nursing school. Thank you in advance for you help.
Old Jan 27, 2008 | 06:14 PM
91parkave's Avatar
Bosch platinums are a no-no for any car IMO get a set of denso's or NGK's gap them to the correct spec: and see what happens
Old Jan 27, 2008 | 06:19 PM
bryont's Avatar
From searching the forum I see the Bosh thing being said often. What is the deal with the Bosh's I wonder. Plugs are definitely a cheaper thing to try first. I will give that a shot. Thanks for the quick reply.
Old Jan 27, 2008 | 06:24 PM
91parkave's Avatar
ther just crappy in quality except the platinum 4's i have nothing but positive things to say about that but any other bosch plug is ****
Old Jan 28, 2008 | 08:55 AM
MaxGordon7's Avatar
NGK only for nissan
Old Jan 28, 2008 | 04:00 PM
bryont's Avatar
Well, I almost don't believe it. I did not think that a spark plug change would ever fix this problem. I just couldn't be that lucky. Son-of-a-B if it didn't completely correct the missfire under load. Put in NGK G-powers and all is good. Take the plugs and add the fact that the knock sensor was bad for who knows how long and the car feels like I did some bolt on HP mods. Thank you for the info.
Old Jan 28, 2008 | 04:28 PM
max ride 41's Avatar
you guys remember splitfires??? what a joke, supposed to give you twice the sparh hence more power, what junk they were.
Old Jan 28, 2008 | 05:18 PM
bryont's Avatar
Yeah, I rememeber them. I am glad to say that I never gave into the marketing. However, I have been known to use some snake oil (lukas) a couple of times when a tranny was on it's last leg.
Old Jan 28, 2008 | 06:12 PM
cefiro80's Avatar
NGK's if that doesnt work look at coils.
Old Jan 29, 2008 | 03:58 AM
bryont's Avatar
NGK's fixed it.
Old Jan 29, 2008 | 04:03 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Nearly as old as this thread.......nearly.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
WeetoddA32
Aug 16, 2015 12:45 PM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
