Putting down the power
Old May 11, 2005 | 07:05 PM
I30tMikeD's Avatar
Looks like it will be a month or two before I turn the boost up. Sent my ECU into JWT and they said at least 3 weeks....so probably two months
I was gonna pruchase a used JWT 550, Z32 program but it was for an auto Maxima and I decided I did not want to put up with the CEL's. I would have had to remove the injectors, MAF, and put the stock ECU back in for emissioins testing. So I just said *** it and sent my I30 ECU into JWT
So in the mean time I got some other goodies to play with. Some 245/50/15 Dunlop SP 8000. Not my first choice in tires but they are literally the only company that makes a wide sticky 15" tire. My 215/60/15 Potenza RE950's are great tires but they can't begin to hold my current 260wtq, let alone what I will be putting down with 10-11 psi.
Also picked up an MEVI so my power will stop falling on it's face after 5.5K rpm's. The 7.2K rev limiter and MEVI will be sweeeeeeet! Once I am out of first I will never see anything below 350 whp.
Old May 11, 2005 | 07:22 PM
GodFather's Avatar
Made in Taiwan
yeah, good move, MEVI is sweet dude.
so you're turbo-ed now. I don't see you much in the 4th gen forums anymore. need to holla back and show us your expertiese sometimes, you know.
Old May 11, 2005 | 07:29 PM
Bags's Avatar
VG Ridah's Biatch Hoe
good deal and good luck on the wait
Old May 11, 2005 | 07:40 PM
matty's Avatar
Crack open that MEVI Lid and make sure those screws are in with RED locktight
Good luck with it all
-matt
Old May 11, 2005 | 09:04 PM
I30tMikeD's Avatar
I still read the 4th gen forum every couple days but never feel like posting. Mostly in here and reading old posts by the more expierenced boosted guys
Old May 11, 2005 | 09:05 PM
I30tMikeD's Avatar
-matt
Most definately.
Old May 12, 2005 | 08:55 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Take some pics PLEASE...I haven't seen what the MEVI looks like inside.
Originally Posted by I30tMikeD
Most definately.
Old May 12, 2005 | 09:16 AM
I30tMikeD's Avatar
Sure. I was actually going to paint the top cover and lock-tight the screws today so I will take pics for you. I know I have seen other post pics with the top removed before....what exactly do you want to see? The butterfly valve system?
Old May 12, 2005 | 09:23 AM
IceY2K1's Avatar
Yeah, how it works basically.....individual butterflys/rod/etc.
I can find others posts, just figured it would be easy/fast for ya, so don't bother if it's a PITA.
Old May 12, 2005 | 09:31 AM
I30tMikeD's Avatar
No, it is not a problem to do. Like I said, I planned on messing with it today.
Old May 12, 2005 | 10:10 AM
$tillenmax2k
What wheels are you going to put the 245's onto? 15" wheels with turbo must accelerate pretty quick!
Old May 12, 2005 | 10:18 AM
I30tMikeD's Avatar
15x7.5 15lb rims off a early 90's Q45. I love rolling on my 15's I don't pretend to road race or autox so I don't need a lower profile tire. Just acceleration baby!
http://img.photobucket.com/albums/v1...d/106_0654.jpg
http://img.photobucket.com/albums/v1...d/106_0657.jpg
http://img.photobucket.com/albums/v1.../moneyshot.jpg
Old May 12, 2005 | 10:43 AM
$tillenmax2k
I see, that's pretty cool. They look similar to old I30 wheels. But i would strongly recommend getting wider wheels, as 245's is too wide for such a narrow wheel.
Old May 12, 2005 | 10:48 AM
IceY2K1's Avatar
Per Tire Racks website the manufacturer recommended rim width range is 6.5"-9.5". He's fine on 7.5" rims.
Old May 12, 2005 | 11:11 AM
I30tMikeD's Avatar
Yep, I would not try squeezing on too wide of a tire on a narrow rim. And since they are 15's there is more side wall flex to work with.
Old May 12, 2005 | 11:21 AM
subs1000w's Avatar
man i might have to pickup 2 of those wheels at the junkyard thats a good size
i ran a 235 on stock 3rd gen 6.5 wide rim it was alittle strang looking but was fine so 245 on a 7.5 should be no problem ive read about NA 300zxs running 255s on a 7.5 in the back
Old May 12, 2005 | 11:42 AM
I30tMikeD's Avatar
I actually have a lead on another set of 4. I only need two, would you be interested in the other two. Don't have a price yet, but it is kind of a "hook up" situation so I think it would be cheap
Old May 12, 2005 | 11:47 AM
Nealoc187's Avatar
SLOW
Every tire manufacturer I can think of says 245 is fine for a 7.5" rim until you start getting down into the 40 and lower profile.
Old May 12, 2005 | 05:06 PM
I30tMikeD's Avatar
Here you go Icey
http://img.photobucket.com/albums/v1...d/114_1472.jpg
http://img.photobucket.com/albums/v1...d/114_1473.jpg
http://img.photobucket.com/albums/v1...d/114_1474.jpg
http://img.photobucket.com/albums/v1...d/114_1475.jpg
http://img.photobucket.com/albums/v1...d/114_1476.jpg
Old May 13, 2005 | 01:24 PM
Jason R's Avatar
aka UNCDooD
nice. can't wait to see some track times after you get your ecu back. car is looking good Mike.
Old May 13, 2005 | 06:08 PM
I30tMikeD's Avatar
Thanks!
Old May 13, 2005 | 09:11 PM
superdave2
damn Mike, those tires got some meat! Are they mounted up yet?
Old May 13, 2005 | 09:54 PM
I30tMikeD's Avatar
Nope, before you get here they will be though.
Old May 14, 2005 | 06:03 AM
C MAX's Avatar
same here i have 16's that i ride on most of the time and throw my 3,000 18's in the garage. the power is so better focused on smaller rims.
Old May 15, 2005 | 09:01 AM
Broaner's Avatar
2060lbs and falling...
With a 50 series it'll be no problem putting 245 on a 7.5".
Man fxck keeping the VI operational. You need to remove torque. Just pull the plates man. I burn down 245's in first and second and I'm not even boosted.
Old May 16, 2005 | 06:17 PM
I30tMikeD's Avatar
Mounted, balanced, and aligned!
Old May 16, 2005 | 07:07 PM
subs1000w's Avatar
looks good and ill let you know if i want the rims but ive need to get the car running again first
Old May 16, 2005 | 07:23 PM
$tillenmax2k
No offense, but those tires look very funny on there. I bet straight line traction must be pretty good with that squishy tire footprint. But when the sidewalls rollover in a turn, watchout!
Old May 16, 2005 | 07:36 PM
I30tMikeD's Avatar
They will be fine, thanks
Old May 16, 2005 | 08:23 PM
Nealoc187's Avatar
SLOW
They look good to me.
Old May 16, 2005 | 08:44 PM
superdave2
Those look sic Mike! All business.
Old May 17, 2005 | 10:25 AM
Broaner's Avatar
Thats what the rear of my 240 is gonna look like. If they have strong sidewalls rollover should be minimal with 40+ PSI.
Old May 17, 2005 | 08:19 PM
TsingTsaoNYC's Avatar
Muscle Car style!!!
lowpost99
Oct 26, 2025 06:53 PM
Maximan190
Dec 16, 2015 06:01 AM
trungg86
Sep 4, 2015 04:58 AM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
