has anybody regreased their starter?
Old May 16, 2001 | 06:02 PM
Daddy Fat Sacks's Avatar
i am in the process of putting my starter back together. when i took it apart, there was a rubber piece in the shorter chamber that just fell out and i don't know which way it was set in there. anybody help? also where did you put grease and did it work?
Old May 16, 2001 | 06:24 PM
emax02's Avatar
I've never heard on anyone rebuilding a starter before. The problem probably has nothing to do with grease, more likely it is a part inside the starter that has died. Just go out and buy a new one. BTW even if you did somehow fix the starter chances are it would just brake on you again. Check around your local auto parts stores because a new Nissan one is probably way over priced.
Old May 16, 2001 | 06:27 PM
i'm not rebuilding the starter. i took it apart to regrease it and clean it...which several people have done in the past...and now i'm putting it back together
Old May 16, 2001 | 06:28 PM
deezo's Avatar
I was waiting for you to reply to the other post. Can you take pictures to show us?
Old May 16, 2001 | 06:34 PM
nope, i don't have a digital camera or a scanner.
Old May 16, 2001 | 06:37 PM
i sent you a private message
Old May 16, 2001 | 08:10 PM
deezo's Avatar
Dude why don't you send it to me. I'll get it back together.
Old May 16, 2001 | 08:39 PM
yo, you won't believe this. i was trying to put everything together so i can put it away and every piece i put in somehow just fell into place, and that rubber piece was in-between the 2 compartments. everything is together and i'm gonna try it in the morning. i'll let you know how it goes.
Old May 17, 2001 | 03:41 AM
deezo's Avatar
I knew you were ****ed when you just broke out. I was like "damn" then I turned the PC off went turned on the TV to watch Martin. I hope I did help you out some tho. Good luck.
Old May 17, 2001 | 03:51 AM
You helped me so much, cuz I wouldn't of figure out how to put it back together and I didn't know if I was greasing it right. And you helped me.
Thanks, man
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
