Garage Door Opener
Old May 18, 2001 | 06:25 PM
KiLIAkLoWn's Avatar
I was tring to get my Garage door programed into my Max's thing one the visor. I followed all the instructions but it still didn't work. Is ne one having a problem with there Max's Door opener??
Old May 18, 2001 | 06:53 PM
Ravq's Avatar
It could be the garage door unit is not compatible with the visor remote. I recall reading it here on the BBS some time back. There are certain brands that it won't work with.
Old May 18, 2001 | 09:19 PM
ikSardarG's Avatar
I dont think you should have a problem with your compatiblity, if you have big name garage door opener, and it isn't brand spankin new. The new ones prolly have a new algorithm scheme for the codes that the max doesnt have (assuming you have a 4th gen of course...) I dont think that there is anything wrong with the opener, since it is always hot at 12volts not switched (I think, without a fuse anywhere). I have a craftsman opener (4 years old) ... Worked the first time I tried... Good luck.
Old May 19, 2001 | 03:38 AM
javamax's Avatar
I have the same problem, but my opener is an ancient All-O-Matic. I don't think the car is the problem, but I'm not ready to buck up for a new opener! Did you try the Canadian programming routine too (you have to cycle/pulse the remote)?
Old May 19, 2001 | 05:51 AM
dvpatel99se's Avatar
Garage Door Opener
WHen I tried to program mine it did not work. I have a 4th gen and just bought a new house. So, I had the GDO(Garage Door Opener) manual. It said to reset the GDO by pressing a red button on the back. I did that and then reprogrammed the two remotes and then tried the max and it worked!!!! BUt sometimes I have to press the button twice on the max and other times only once. But hey, I always carry the remote regardless so that I am not locked out. But the GDO works.
Now I am trying to program my security system remote too. But ADT said that it will not work. Anybody did that with the ADT security system? Does it work?
Old May 19, 2001 | 06:35 AM
dsmercado's Avatar
I have not had any success with my garage door opener.I've tried numerous times but I can't get the visor controls to work. Maybe my garage door isn't compatible?
Old May 19, 2001 | 08:55 AM
Nick97SE's Avatar
Mine worked when I did it.
I think I might now what the problem with some of your guys' garage door openers might be. If you have a rolling code on your garage door opener, there is another way you have to program it. I forget how though.
-Nick
Old May 19, 2001 | 11:08 AM
ikSardarG's Avatar
-Nick
I have a rolling code system on my Craftsman opener and the Max didnt have a problem with it... Our '99 Town and Country Limited van did at first, but then finally obtained the algorithm... Homelink (the visor buttons) are designed to learn the algorithms, not just the radio frequency... (That's what I have heard...)
Old May 20, 2001 | 09:23 AM
KiLIAkLoWn's Avatar
Craftsman
I have a 2000 Craftsman GDO and the HomeLink thing said it should work on all new ones from 85'-present
Old May 20, 2001 | 09:50 AM
maxkid77's Avatar
so, does that mean that you can go open anybody's garage? Also does the battery need replacing after a while?
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
magiconthetire
Oct 26, 2015 09:03 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
