Window washer not working, any suggestions?
Just noticed yesterday that my windshield washer does not work. I added fluid, still nothing squirting out. I checked the fuses under the dash, and the one next to the battery box marked " window deicer", all fuses good. Any idea where to start my trouble shooting, a quick peek before work and I do not even know where the washer pump is.......
Originally Posted by Zog
Did you install a FSTB recently? Sometimes the line gets crimped by the bar. Also you could check the line and make sure there's not a blockage or crimp in the line.
It should be at the bottom of the washer reservoir.
Not sure of how the configuration is on the Max, but an old GM car I worked on years ago had a little screen at the bottom of the tank to serve as a crud filter. Turns out the screen had gotten pretty clogged over the years and wasn't allowing enough fluid through.
+1 on the pin idea.
+1 on the pin idea.
jerrod99_se-l
Aug 27, 2015 08:27 PM
jchronis2552
Aug 13, 2015 07:48 AM
kjm900r
Aug 5, 2015 07:14 AM
