Just want to verify with peeps that have upgraded ECU's
I checked my codes just to see if all was clear (besides the rear 02 code, which is normal) and saw the knock sensor code. I didn't notice it when I first installed the ECU but the car still runs strong. Is the knock sensor code legit on the 96 auto ECU in a 97 auto?
I figure the knock sensor won't last forever so it might need replacement. I have 176000 on the car.
If you need help I can change it and also fix that rear o2 code with a o2 simulator circuit. On my car I don't even have a rear o2 sensor anymore, I use a o2 sim from http://www.o2simulator.com/ and two 15 ohm 25 watt resistors in series to trick the ECU heater circuit.
Originally Posted by 98SEBlackMax
Yeah its possible that the KS is bad. With the advanced timing of the ECU it prob doesn't feel like there is power loss, but im willing to bet there is less power there.
Am I buying the single output or dual output universal?
We'll need to hook up. I'll let you know when I get everything. My hands are probably too big to fit down in that opening anyway.
You can get either, I got the single output for simplicity. Also I would get two 100 ohm 25 watt resistors or two 25 ohm 25 watt resistors for the heater circuit. I used a pair of 15 ohm 25 watt resistors in series and the project box gets hot after running for a while. I did a search and found that guys are going as high as 50 ohms and the ECU doesn't throw a heater code. The higher resistance we can use the less heat it will put out.
same problem
I just got a 96 auto ecu for my 97 auto. I have yet to get the ecu upgraded...probably gonna go JWT since I have a MEVI. I drove around just to make sure the ecu works, and after a day, I got 2 codes...KS code and rear O2 sensor code. I know I don't have a bad KS because there are no codes when I use the 97 ecu. I would definately like to get rid of the rear O2 code also, but if the KS code is still gonna be there, I don' tsee the point in using the sim circuit.
You can also buy a '96 rear o2 sensor and rewire it to work on a '97~'98 harness as well. But I think its easier and cheaper to just buy the simulator
and wire it up to make the '96 ECU think the rear o2 is present. This will require moving a wire from pin 107 to pin 105 on the ECU main harness and adding a ground wire to pin 112. (Credit: ENG92)
I think if Deezo wants to go thru with this his car will be the first to have a '96 ECU in a '97~'98 using a o2 sim. Since the '96 and '97 rear o2s are so different mechanically and electrically the simulator is an easier soultion IMO.
You know, it's funny.. I've got a 96 ECU in my 98 and I moved pin 107 to 105 and added a ground line on 112 and I've never gotten an O2 code at all. Still my 4-wire zirconia sensor in place, no O2 sim or resistors or anything, yet never one rear O2 code. I expected to get one but hey, don't look a gift horse in the mouth right? hehe
Hmmmnnn...I've got a friend with a '97 turbo'd that might be interested in that.
Has anyone else done this without a code? Do you have any codes/CEL?
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
