urgent how much tire pressure needed for maxima
Old Aug 13, 2005 | 09:04 AM
kasemodz's Avatar
how much tire pressure do i need for my 97 maxima gle. I have bridgestone touring tires. Im going on vacation so I need to fill em up.
Old Aug 13, 2005 | 09:21 AM
DAVE Sz's Avatar
Hooooooonda.....
see what the max psi on the tire is, for a long trip inflate the tire to max and take away maybe 5-6 psi. It's suppsed to be 32psi, which is what nissan says, but that makes the tires look flat, kills gas mileage, and is mostly for comfort.
Old Aug 13, 2005 | 09:56 AM
Jatan's Avatar
I keep mine at 35psi all around
The stock psi should be under your armrest cover, but like Dave said, its too low
Old Aug 13, 2005 | 10:14 AM
njmaxseltd's Avatar
Your tire pressure should be checked first thing in the morning before the car is driven when the tires are cold. 32 PSI all around should be just fine for your touring tires.
The pressures indicated on the tire's side wall are for the tires maximun load capacity only. That's not necessaraly what your car's tire pressure should be set to. Excessive tire pressure will decrease the tires tread contact patch and can cause it to loose traction faster then if it were inflated to the vehicles specifications.
The steering may "feel" tighter with more tire pressure, only giving you a false sense of better handling.
Old Aug 13, 2005 | 01:32 PM
cds166's Avatar
35-37 for me
Old Aug 13, 2005 | 01:47 PM
99Automagic
It also depends on the brand of tire. My ZE512's, the "recommended" pressure from Falken is, 42lbs, max is 50, so it kind of goes along with what that dave kid said.
Old Aug 13, 2005 | 07:02 PM
NY 95 VQ30DE's Avatar
well just like you, i run about 20 psi. unless im going on vacation. then i fill them up to 35-40 psi. haha j/k i always run 35-40 psi in my falken 451's. but just wondering....why would you only fill them up becasue youre traveling. you should check them once a month at least, and keep them inflated within a pound or two of each other.
MplsMadMan
Sep 4, 2015 02:23 PM
TonyJr
Aug 20, 2015 12:14 AM
District
Aug 15, 2015 08:23 PM
acw
Aug 13, 2015 12:50 AM
mls277
Aug 11, 2015 07:18 PM
