key less entry
Old Sep 10, 2005 | 02:43 PM
NJMAX's Avatar
Key less entry question?
Does anybody know where the factory key less entry receiver is located on a 2000 Max SE. Also do you know if it has a fuse in it? Any help is much appreciated. Thank You.
Old Sep 10, 2005 | 02:46 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Fuse #13, 10A
Old Sep 10, 2005 | 02:56 PM
NJMAX's Avatar
i checked the fuses they are all good. i need to know the location of the receiver. where is 13 located? thanks
Old Sep 10, 2005 | 03:04 PM
Holy s hit. I did not just read that. FUSE PANEL IN YOUR CAR...FUSE #13!!!!!! How did you check the fuses if you don't even know where the 13th fuse is?!
Old Sep 10, 2005 | 03:06 PM
NJMAX's Avatar
i don't know about your car but my car doesn't have numbers indicating fuses
Old Sep 10, 2005 | 03:18 PM
NJMAX's Avatar
Metal, if your so smart why don't you tell me where the key less entry receiver is located.
Old Sep 10, 2005 | 03:56 PM
2k1Maxdrvr's Avatar
Hey man don't mess with Metal you WILL need his help in the future!!! He is one smart cookie when it comes to Max's........
Old Sep 10, 2005 | 09:47 PM
TungstenBlue02's Avatar
It's located under the steering wheel.
Here is the picture of it:
Old Sep 11, 2005 | 05:20 AM
NJMAX's Avatar
Thanks Blue. I appreciate your help. do you know if the control unit has a fuse? and also i like to know where did you find the picture?
thanks again.
Old Sep 11, 2005 | 09:20 PM
You're welcome. I captured the picture in the 2002 Maxima Service Manual.
I don't think there's fuse in the Smart Entrance Control Unit. However, there're fuses for the Remote Keyless Entry System in the fuse box. Did you check the fuse box and fusible link box?
Old Sep 12, 2005 | 02:59 AM
NJMAX's Avatar
Thanks again. I checked all the fusues and replaced the key less relay to no avail. my next step is to replace the control unit. i'll be going to a junk yard today. i'll keep you posted. Again, thank you very much.
Old Sep 12, 2005 | 11:59 PM
You're most welcome. Good luck to you!
Old Sep 13, 2005 | 05:23 PM
BewstAdd1ct's Avatar
umm, before you go replacing modules... there are THREE fuses for the SECU. if your keyless isnt working, but the pl are, try replacing your transmitters battery
Old Sep 13, 2005 | 06:01 PM
NJMAX's Avatar
BewstAdd1ct
Thanks for you help. I really appreciate all the help i can get.
I checked all visible fuses. I'm Sorry i don't understand what (pl) is. Can you tell me which 3 fuses are for the SECU. My interior lights and Locks don't work, everything else works.
Thanks Again
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 16, 2015 02:53 AM
jerrod99_se-l
Sep 19, 2015 06:54 AM
flu2000
Sep 14, 2015 12:34 PM
