Known 2K2 Issues
Known 2K2 Issues
OK guys, I did a search and found a few threads, but nothing really useful. On friday I'm going to look at a 2k2, 6 spd, with 31.5K miles and I want to know if theres anything specific with that year I should take a look for. I know all the general stuff, but I've never had a 6spd, or a 3.5, so I just want to make sure I'm covering all my bases when I check the car out.
I would also try and find out if all the ECM "updates" have been done which help solve "hesitation" problems and O2 sensor DTC problems.
Other common problems........Bose stereo left side speakers don't work when playing CDs, hood rattles (i.e. looks like it's about to fly off) at highway speeds, excessive wind noise from the back windows at highway speeds. There's also a couple of recalls you should confirm have been done if they apply to your VIN #.
These are all problems I have seen on my 2K2 so I speak from experience. Annoyances, but nothing major. I still like my car.
Same issues as my 2003..
The only issues I've had is that my Bose still sucks even after getting 2 head units replaced under warranty and wind noise (which can be easily fixed but I haven't bothered). No hood rattle or MAF issues yet.
Originally Posted by NmexMAX
Did you fix the sunroof wind noise or the rear window deal?
Originally Posted by BewstAdd1ct
sone early build 02s have a camshaft actuator rattle on startup, replace failed part with updated actuator, mine doesnt have the problem.
I just discovered this rattle recently and I am only 3K from being done my powertrain warranty so I need to get it fixed soon assuming it is covered under that warranty. I would just like to make sure I know what I'm talking about before I go to Nissan so I don't get the typical runaround.
Originally Posted by BigFly_2K2SE
MAFs are a big problem on the 2K2's, especially the ones with early build dates. Take a look at the MAF and see if it is the AM600 part number. If it is, you are in luck....if not, prepare to replace it soon.
The hood rattle he is talking about is only at high speeds from the wind resistance. The simplest solution to this is adjusting the rubber thingies on the right and left side of the hood for 5.5th Gens. This has not completely solved the problem, but it does reduce it. As far as hood rattle when you are in park, that sounds like a really rough idle.
[QUOTE=TXT-1]The hood rattle he is talking about is only at high speeds from the wind resistance. The simplest solution to this is adjusting the rubber thingies on the right and left side of the hood for 5.5th Gens. This has not completely solved the problem, but it does reduce it. As far as hood rattle when you are in park, that sounds like a really rough idle.[/
I wish that were the case but the problem it usually happens while im driving or stopped...it jus comes out of nowhere sometimes and i have no idea what it could be...from reading other threads only thing i can think of is bad coils...ne ideaz....???
[QUOTE=ShIft_uR FacE]
Timing chain maybe? http://maxima.theowensfamily.com/tsb/NTB03-060.pdf
Originally Posted by Shogunsc4
PINGS!!!!! Other than that...I have a 2k3 and issues I had were, 4 blown MAF's, 2 bad TB's, a bad ECU...and did I mention that it pings?
Originally Posted by wope
i am very close to buying a used 2k2 with 60k miles but this thread is sort of scaring me..
Like I mentioned earlier, the only major thing I would think about is the issue of HID theft. If you live in an area where this is a problem, think twice.
Granted, I've only had mine for 3 months, but I was able to goto the service Nissan dealership and have every maintance printed out.
So far with 54k miles my car has had the brakes replaced and new o2 sensors. Other than the regular oil and service intervals it has been pretty close to flawless!
As with any car, look for the absolute cleanest and pristine example you can find!
Can you elaborate on this Bewst? Is this the "cold start rattle" TSB that I've read about?
Classification:
EC03-016
Reference
NTB03-060
Date:
June 18, 2003
2002 MAXIMA AND ALTIMA WITH VQ35 ENGINE; RATTLE NOISE WHEN STARTED COLD.
APPLIED VEHICLE(S):
2002 Altima (L31) with VQ35DE engine.
2002 Maxima (A33)
APPLIED VIN(S):
2002 Altima built before 1N4BL11D(*)3C 210299
2002 Maxima built before JN1DA31A(*)3T 438232 or
JN1DA31A(*)3T 524380
APPLIED DATE(S):
2002 Altima built before January 17, 2003
2002 Maxima built before November 20, 2002
APPLIED ENGINE:
VQ35DE
IF YOU CONFIRM:
The engine in an applied vehicle makes a rattle noise for about 1 second when started cold,
DETERMINE IF:
The noise is coming from the left or right side VTC (Valve Timing Control) sprocket.
ACTION:
Replace the VTC sprocket that is making noise.
PARTS INFORMATION
CLAIMS INFORMATION
IMPORTANT: The purpose of 'ACTION' is to give you a quick idea of the work you will be performing. You MUST closely follow the entire Service Procedure as it contains information that is essential to successfully completing this repair.
SERVICE PROCEDURE
1. Determine if the noise is coming from a VTC sprocket, and which one (left bank or right bank).
a. Do not start or run the engine for at least 4 hours (cold-soak).
^ Overnight "cold-soak" is preferred.
b. Have one person start the engine while a second person is near the front of the engine to listen for the noise.
^ Listen around the VTC sprocket areas.
NOTE: The incident noise will last for only about 1 second.
2. Replace the VTC sprocket that is making noise.
^ Refer to the appropriate Service Manual (ESM), section EM, for VTC sprocket replacement procedures.
^ A very small amount of noise from the new VTC sprocket during a cold start is considered normal and acceptable.
EC03-016
Reference
NTB03-060
Date:
June 18, 2003
APPLIED VEHICLE(S):
2002 Maxima (A33)
APPLIED VIN(S):
APPLIED DATE(S):
APPLIED ENGINE:
VQ35DE
IF YOU CONFIRM:
DETERMINE IF:
ACTION:
PARTS INFORMATION
CLAIMS INFORMATION
SERVICE PROCEDURE
and yea, shogun... your car is a lemon...
j/k
Mar 12, 2020 12:06 AM
BrandonCause
Sep 14, 2015 10:41 PM
with TXT-1 as well.
