HELP!! A/C Related
Old Oct 16, 2005 | 04:51 PM
StillenMax80x20's Avatar
HELP!! A/C Related
need a further readout of test results... have auto climate control test performed, on test 2 result was -24 and 25, then on test 51 ambient temp and cabin temp read fine, but with the engine hot or cold the 3rd temp readout was 131 deg F
these are results after 3 tests, 2 cold starts and one warm.... all with the exact same outcome...
can't find out what they mean, but i imagine i need a new water temp sensor, my hot air is affected.
Old Oct 18, 2005 | 03:44 PM
BewstAdd1ct's Avatar
what was the original problem with the a/c?
Old Oct 18, 2005 | 03:51 PM
-24 is the intake sensor, and 25 is the sunload sensor. if you did the test inside or at night, youll throw a 25 every time. Svc manual suggest shining 60W or brighter light in the sunload sensor to ck it.
i can email you a picture with the general location of the sensor, PM your addy to me.
Old Oct 18, 2005 | 06:11 PM
the original problem w/ the a/c is the heat turns on ONLY at 85 degrees, but it sends it to the floor as though it were heat at 73-77 but it's cold.
I did run 2 tests in the day and only hit a -24, and if the third temp read-out (in test 51) is the intake sensor, it's faulked cause every test...(6 total, sun twice) cause it's read 131 degs everytime!
Old Oct 18, 2005 | 07:28 PM
id bet thats your problem, the sensor is reading that high temp, and adjusting the blend door for cooler air.
disconnect the sensor and check the reading again.
Old Oct 18, 2005 | 09:53 PM
bewstaddict
i seem to be having problems sending pm's.....
andy@thrifty-signs.com
please send a photo or pdf or pic of whatever would be helpful to my broken air intake sensor. Thanks for the help and tests, i honestly wasn't sure anything was wrong til i read another of your posts.
thanks
Old Oct 19, 2005 | 10:32 AM
ecr72's Avatar
I have a 2000 GLE with what sounds like the exact same problem. I thought my wife was crazy complaining about 'frozen feet' and having to turn the temp to 85 just to get it to blow warm air. Then I took it for a spin and sure enough, 84 was blowing cold air on my feet and 85 degrees would blow warm. When she first mentioned it I was freaking out thinking it was going to be the heater core. After my quick check I assumed it was whatever sensor measures the air temp inside the car.
Anyway, can you send me whatever info you have on this problem or the fix? Pics, pdfs, p/n of sensor... ecr72@sbcglobal.net
I've been searching on this topic and can not find much so far.
Old Oct 20, 2005 | 06:51 PM
you both have mail. ecr, try runnning the diagnostic process as referenced earlier int eh thread. you can more easily locate the problem, as it could be a few other things, including a cabin temp sensor.
EDIT: sorry different thread has the refernce, ill find it for you
Old Oct 20, 2005 | 06:54 PM
this was some of it:
http://forums.maxima.org/showthread....ds#post4248498
Old Oct 20, 2005 | 06:55 PM
ecr if you still dont find anything, ill send you the images of the diagnostic.
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
jfl330
Sep 4, 2015 01:44 PM
